I solved this problem after I tried many solutions and finally I found that I use a wrong cables the uhd 630 works on hdmi 1.4 cable, edp 1.4, and dp 1. 2 as listed in the specifications of uhd 630. I posted this problem to help this problem quickly
Hello AThab1,
Thank you for posting on the Intel Communities.
I am glad to know that you were able to resolve the issue by using a supported cable version for this Intel® UHD Graphics 630 adapter.
Thank you for sharing the fixes of your flickering issues.
Abigail G
Under Contract to Intel Corporation.
