hossameid, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
Which Windows* version are you using?
What is the name of the games?
Please attach the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
Albert R.
yes I bought it 4 months ago.
no .
When I bought a laptop I am having this problem.
And I updated all the definitions to cut off the device’s resources from the official Dell website by using the service tag Attached is a laptop box .
21H1 build 190.43.1055
In all games like ( pes 21 + fifa 21 + Grand Theft Auto V +WWE.2K20+ Pro Evolution Soccer 2017....
Songs from a problem in all games have been tried
in the two
hossameid, Thank you very much for providing that information and the SSU report.
Just to confirm, did you check the system requirements of the games to make sure your system complies with them?
After checking the SSU information, we can see that the graphics driver currently installed is version 27.20.100.9466, which is an Intel® generic graphics driver.
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked in Dell's website and the graphics driver they have available is version 27.20.100.8935, A03, please try a clean installation of that driver following the instructions in the links below:
If the problem persists after that, we can try a clean installation this time of Intel® Beta generic graphics driver version 30.0.100.9667:
https://downloadcenter.intel.com/download/30522/Intel-Graphics-BETA-Windows-10-DCH-Drivers
Also, please get in contact directly with Dell to make sure that the latest BIOS version is currently installed in your system or to gather the instructions on how to install it:
https://www.dell.com/support/home/en-us
Albert R.
no .
in the two
Hello hossameid, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Hello hossameid, Thank you very much for your response.
But what we wanted to confirm is if you were able to install the graphics drivers provided previously and doing the BIOS update to the latest version and if the problem remains after that?
Albert R.
Hello hossameid, I just wanted to check were you able to install the graphics drivers provided previously on this thread and doing the BIOS update to the latest version?
Albert R.
I have done everything there is the same problem what is the final solution please help
hossameid, Thank you very much for sharing those results.
We are sorry to hear the issue persists, we will do further research on this matter, as soon as I get any updates, I will post all the details on this thread.
Albert R.
Hello hossameid, I just received an update on this matter.
Just to let you know, for this specific scenario, the games should be running in the RTX 2070 graphics controller.
So, just to make sure, could you please confirm if the issue also happens when using just the Intel® Graphics controller?
Additionally, are the games running on the same platform, e.g. Steam?
Albert R.
Make sure that I play on the Nvidia card. I play games on Steam and also Oregon, and I have the same problem. I want a radical solution to this problem. Please review the problem well, because I am very bored.
hossameid, Thank you very much for letting us know those details.
We understand that the problem persists when running the games on the Nvidia card, but for us to be able to do further research, could you please confirm if the issue happens when using just the Intel® Graphics controller only?
Albert R.
When using a card Intel® Graphics, there is severe pain and there is no stability because it is weak
hossameid, Thank you very much for confirming those details.
We will continue with our research on this matter, as soon as I get any information I will post all the updates on this thread.
Albert R.
For this specific scenario, just to let you know, the systems with hybrid graphics are highly customized and are designed to run the highly demanding graphics tasks with the eGPU. So what we recommend as the best thing to do, will be to use the manufacturer's drivers for both graphics cards. In the video, you shared with us, you were using the Nvidia card, and we do not have control or information about the specific settings you should use while running the game on an external card.
We can only provide troubleshooting for the Intel graphics card, and in that case, you should disable the Nvidia one and provide us with steps to replicate this using just the Intel Card. However, you will have a better performance using the Nvidia card since the PC was designed as we mentioned before to run the games with that graphics card, our best recommendation is to continue working with Nvidia and Dell, if you are using manufacturer's drivers both cards should be working properly with your system and only Nvidia can provide the specific settings they recommend to play the games you are currently running.
Albert R.
What is the way to operate two cards for each benefit of better performance
It all depends on the customizations done by the manufacturer of the computer, they customized everything in your platform in order to provide a better overall performance of the unit.
In regard to graphics, they can customize your equipment to assign tasks to each graphics controller, for example, they can assign the games to be supported by the Nvidia graphics card specifically and the rest of the functions related to graphics to be handled by the Intel® graphics controller in order not to overload none of them and have a better performance by sharing assignments, but it is up to them, to Dell, in this case, to confirm if that is actually the way their computer is working and what were the customizations done by them:
https://www.dell.com/support/home/en-us?lwp=rt
Albert R.
