22939 Discussions
I see this error when I update the driver of Intel UHD Graphics 630
Quang_Thinh
I have consulted how to fix errors from a lot on the web but I still can't fix it.
I installed the driver version 26.20.100.7262. I see this error in version 26.20.100.7870.
I hope everyone helps me to fix this problem
AlHill
If the driver has not been validated (by your laptop or destop manufacturer), then it is not validated.
And,even if you force it to install, Microsoft will do a drive by and put you back to 7262.
Doc
Quang_Thinh
So should I use version 7262 or should I update to version 7870? Or i can't update to version 7870?
AlHill
What you should do is to check with your device manufacturer.
Doc
n_scott_pearson
Yes, you should use the most recent driver made available by your laptop/motherboard manufacturer. If this is replaced with a newer version by Windows Update, so be it.
