21803 Discussions
I want to know if Intel Arc A750 is compatible with Gigabyte B250M Gaming 5 DDR4.
rxane
I want to know if Intel Arc A750 is compatible with Gigabyte B250M Gaming 5 DDR4. processor intel i5-7500 CPU. ram 16 gb 2400 bus.
ACarmona_Intel
Hello Rxane,
Thank you so much for posting in our Intel communities.
The minimum Intel processor that works with our Arc graphics card is a 10th-generation processor. Also, I looked at your motherboard specifications and found that it only supports 7th and 6th generation Intel® CoreTM processors.
You can check out this link: https://www.gigabyte.com/my/Motherboard/GA-B250M-Gaming-5-rev-10#kf - GA-B250M-Gaming 5
You can also find more information about our Arc graphics card at these links:
To summarize, your processor (i5-7500) and motherboard (Gigabyte B250M Gaming 5 DDR4) may work with Arc A750 but will not give you its full potential since your configuration is below the requirements of Arc A750. You may experience performance or stability issues with your given setup; hence, we suggest upgrading to one of the configurations in our guide for the best performance with Intel® ArcTM Graphics.
Thank you, and have a great day!
Carmona A.
Intel Customer Support Technician
ACarmona_Intel
Hello Rxane,
We are checking in with you on the concern that we have with the Arc A750 if it's compatible with the Gigabyte B250M Gaming 5 DDR4 in case you have any additional queries or require further explanation. Please know that we would be happy to assist you if you have any.
Carmona A.
ACarmona_Intel
Hello Rxane,
We are checking in with you on the concern that we have with the Arc A750 if it's compatible with the Gigabyte B250M Gaming 5 DDR, as we have not heard any response from you.
Carmona A.
ACarmona_Intel
Hello Rxane,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
