22849 Discussions
Input lag when under 60 FPS in all games with Iris Pro 6200
BPowe2
I'm using an Intel 5775c with integrated Iris Pro 6200, 16GB DDR3 1600 MHz on H97 platform. I've noticed that with all games I've tried (Dark Souls 3, BioShock Infinite, Witcher 3), if the frame rate goes bellow 60 FPS I get significant mouse input lag. V-sync is disabled in games being played. What's going on? How can I fix this? It means all games are unplayable unless I can get them to run at a stable 60 FPS.
Hello gravitysphere,
My apologies for the inconvenience.
I would like to request a test with V-sync enabled, please try one of the games mentioned and share the results. In the meantime, please provide your Intel® HD Graphics version and your computer model. To get the Intel® HD Graphics driver version go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
Thank you.
Amy C.
/thread/116676 gravitysphere, if you need further assistance let us know.
Amy C.
