23256 Discussions
Install HD Graphics 3000/2000 driver to Windows 7 64bit causes BSOD when reboot
I clean installed Win7 64 bit and installed the newest HD Graphics 3000/2000 driver.(# 2321)
After rebooting, I got BSOD. I'm using DVI-D port.And I installed Windows to 3TB HDD with UEFI(GPT). (3TB partition) This problem is not reproduced when I install Windows with MBR. (2TB partition)This problem is still reproduced when I install old driver(# 2291) so I think this problem is not as same as http://communities.intel.com/thread/20439 http://communities.intel.com/thread/20439 Does anyone can use Win7 64bit + HD3000/2000 driver + GPT partition? CPU i5 2500KM/B ASROCK H67M-GE/HTMEM 4G*2HDD HGST 3TBOS Windows7 64 bit
I was having the same problems with Windows 7 64 bit. I am using the Intel board DH67CL. After several attempts, I got it to work by doing the following steps:
1) Clean install using GPT (via UEFI)
2) Install all of the needed drivers except the video drivers
3) Install service pack 1
4) Install all updates from windows update
5) Of course, make sure you have rebooted after installing all of the updates
6) Install video driver and make sure to UNCHECK the test for compatibility with Windows Aero
7) Reboot and hopefully you don't get a BSOD
Thank you!!
I could install the driver without BSOD.
