23077 Discussions
Intel 8805G (XPS 15 2in1) Open GL on Vega Graphics issuss?
SHyde2
I have a brand new XPS 15 2in1 with Intel 8805G and notice in several different situations that Open GL does not used the Vega Graphics instead it uses Intel GPU.
1. Steam VR test applications does not detected the Vega
2. Lightwave 3D 2018 does not detected the VEGA for Open GL
Is there an option for Open GL
1. Global Setting to force Open GL to use a specific GPU
2. Application specific setting for Open GL to specific processor
Following is screen shot for Lightwave 3D 2018 Layout screen
I will put this on the NewTek site for Lightwave 3D 2018
AlHill
Intel HD graphics 630 supports OpenGL 4.5.
Look under 8th gen processors.
https://www.intel.com/content/www/us/en/support/articles/000005524/graphics-drivers.html?eu-cookie-notice Supported APIs and Features for Intel® Graphics Drivers
You will need to contact Dell for support with your dual graphics usage.
Doc
SHyde2
I will guarantee this issue will happen on the Intel NUC with similar chip.
https://www.intel.com/content/www/us/en/products/boards-kits/nuc/kits/nuc8i7hvk.html Intel® NUC Kit NUC8i7HVK
But I guess you are sending me to Dell, because you want them to report it you.
BTW your link has no information on Intel 8805G
https://ark.intel.com/products/130411/Intel-Core-i7-8705G-Processor-with-Radeon-RX-Vega-M-GL-graphics-8M-Cache-up-to-4_10-GHz Intel® Core™ i7-8705G Processor with Radeon™ RX Vega M GL graphics (8M Cache, up to 4.10 GHz) Product Specifications
This is a special dual GPU die created between Intel and AMD and is not vendor specific.
I don't accept you answer as the solution to problem. This is an Intel driver issue.
AlHill
You posted a photo referencing HD 630 graphics.
However, one of the Intel support staff will be able to assist you.
Doc
SHyde2
What I mean is that application don't detected the Vega, it possibly could be applications
I just think it is important that Intel resolves this issue - it would be major embarrassment not to include support.
With 630, my guess is that Vibe VR is supported, but with Vega it likely is supported.
