How do i know which type my chipset is?i need to know ,because there is a difference between the 915 gms and the 915gm chipset.It says that 915 gm has support for ddr2 when used in dual channel ,only gms does not have dual channel,only single channel available.I want to know what do i have to do to use ddr2 instead of ddr.Below are the sepcs i got form intel chipset utility and the ones fro everest and also a link to the laptop's specs.
Thanks a lot.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=513&CategoryID=3&DetailName=Specification&MenuID=1&LanID=0 http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=513&CategoryID=3&DetailName=Specification&MenuID=1&LanID=0
the intel utiliy says:
Chipset
Detected Chipset:
Mobile Intel(R) 82915GM/GMS/910GML Express Chipset family
Chipset Components
Memory Controller:
Mobile 82915GM/GMS/82910GML
I/O Controller:
Intel(R) 82801FBM I/O controller hub (ICH6M)
Integrated Graphics:
Mobile Intel(R) 82915GM/GMS, 910GML Express Chipset Family
everest :
Field Value
North Bridge Properties
North Bridge Intel Alviso-G i915GM
Revision / Stepping 03 / B1
Package Type 1210 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
Memory Timings
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 7T
Error Correction
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots
DRAM Slot # 1 256 MB (PC2700 DDR SDRAM)
DRAM Slot # 2 256 MB (PC2700 DDR SDRAM)
Integrated Graphics Controller
Graphics Controller Type Intel GMA 900
Graphics Controller Status Enabled
Graphics Frame Buffer Size 16 MB
Chipset Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/chipsets.htm http://www.intel.com/products/browse/chipsets.htm
Driver Download http://support.intel.com/support/chipsets/index.htm http://support.intel.com/support/chipsets/index.htm
South Bridge Properties
South Bridge Intel 82801FBM ICH6-M
Revision / Stepping D4 / B2
Package Type 609 Pin mBGA
Package Size 3.1 cm x 3.1 cm
Core Voltage 1.5 V
AC'97 Audio Controller
Audio Controller Type Intel 82801FB(M) ICH6
Codec Name Avance Logic ALC655
Codec ID 414C4760h
S/PDIF Output Supported
PCI Express Controller
PCI-E x1 port # 1 In Use @ x1 (Broadcom NetLink BCM5789 Gigabit Ethernet Controller)
PCI-E x1 port # 2 Empty
PCI-E x1 port # 3 Empty
PCI-E x1 port # 4 Empty
Motherboard Properties
Motherboard ID 63-1646-009999-00101111-041905-Alviso$0ABEU005_BIOS DATE: 04/19/05 19:41:02 VER: 08.00.11
Motherboard Name Unknown
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
Bandwidth 2667 MB/s
Chipset Bus Properties
Bus Type Intel Direct Media Interface
