22928 Discussions
Intel ARC B50 vs B580
Laroldski
I was wondering if a Mod can answer this question.
I was wondering is the B50 faster at video encoding using HandBrake over the B580 as no reviewers never seem to show those test results.
I do a lot of video encoding and I would like to know if the B50 is faster.
DeancR_Intel
Hi Laroldski,
Thank you for contacting Intel Customer Support regarding the video encoding performance comparison between the Intel Arc B50 and B580 graphics cards, specifically for HandBrake encoding workloads.
I understand that you do a lot of video encoding work and are looking for specific performance data that may not be readily available in typical reviews. This is an excellent question, and I appreciate you reaching out for clarification on these technical specifications.
Intel Arc B50 (Pro Series):
Intel Arc B580:
Both cards feature identical media engine capabilities with support for:
  • H.264 Hardware Encode/Decode
  • H.265 (HEVC) Hardware Encode/Decode
  • AV1 Encode/Decode
  • VP9 Bitstream & Decoding
  • 2 Multi-Format Codec Engines each
However, there are important differences that can affect encoding performance:
B580 Advantages:
  • More Xe-cores (20 vs 16) and XMX engines (160 vs 128)
  • Significantly higher memory bandwidth (456 GB/s vs 224 GB/s)
  • Higher power budget (190W vs 70W) for sustained workloads
B50 Advantages:
  • More VRAM (16 GB vs 12 GB) for handling larger video files
  • Lower power consumption for efficiency-focused workflows
  • Pro-series designation with potential driver optimizations
Given the technical nature of your inquiry and the specific workload requirements you have, I'd like to offer you a phone consultation for faster communication and more detailed discussion.
Dean R.
DeancR_Intel
Hi Laroldski,
Dean R.
DeancR_Intel
Hi Laroldski,
As you have been unresponsive, I will proceed to close this thread. If you wish to continue the discussion or need further assistance, please feel free to create a new thread. This will help us provide focused support and ensure your concerns are addressed effectively.
Dean R.
