23272 Discussions
Intel Arc A380 drivers in headless Ubuntu 24.04 LTS
trademarkej
I recently spun down a VM running Ubuntu Server 22.04 LTS in favor of a new one running 24.04 LTS and am now unable to get my Intel Arc A380 working.  I have already tried the suggestions from a similar post Intel Arc drivers in Ubuntu help  and the instructions for Installing Client GPUs. Any thoughts?
System Info:
uname -r
6.8.0-45-generic
lspci -k | grep -EA3 'VGA|3D|Display'
01:00.0 VGA compatible controller: Intel Corporation DG2 [Arc A380] (rev 05)
        Subsystem: ASRock Incorporation DG2 [Arc A380]
        Kernel modules: i915, xe
Errors encountered:
journalctl -b | grep intel
Sep 23 12:35:36 rke2-agent-02 kernel: snd_hda_intel 0000:00:1b.0: no codecs found!
Sep 23 12:35:36 rke2-agent-02 kernel: snd_hda_intel 0000:06:11.0: error -ENODEV: HSW/BDW HD-audio HDMI/DP requires binding with gfx driver
journalctl -b | grep i915
Sep 23 12:35:38 rke2-agent-02 kernel: i915 0000:01:00.0: [drm] *ERROR* Device is non-operational; MMIO access returns 0xFFFFFFFF!
Sep 23 12:35:38 rke2-agent-02 kernel: i915 0000:01:00.0: Device initialization failed (-5)
Sep 23 12:35:38 rke2-agent-02 kernel: i915: probe of 0000:01:00.0 failed with error -5
sudo dmesg | grep -i i915
[  469.071669] i915 0000:06:10.0: [drm] *ERROR* Device is non-operational; MMIO access returns 0xFFFFFFFF!
[  469.072615] i915 0000:06:10.0: Device initialization failed (-5)
[  469.073070] i915 0000:06:10.0: Please file a bug on drm/i915; see https://drm.pages.freedesktop.org/intel-docs/how-to-file-i915-bugs.html for details.
[  469.073073] i915: probe of 0000:06:10.0 failed with error -5
I have also installed the following packages as part of my troubleshooting:
sudo apt install -y \
  intel-opencl-icd intel-level-zero-gpu level-zero intel-level-zero-gpu-raytracing \
  intel-media-va-driver-non-free libmfx1 libmfxgen1 libvpl2 \
  libegl-mesa0 libegl1-mesa libegl1-mesa-dev libgbm1 libgl1-mesa-dev libgl1-mesa-dri \
  libglapi-mesa libgles2-mesa-dev libglx-mesa0 libigdgmm12 libxatracker2 mesa-va-drivers \
  mesa-vdpau-drivers mesa-vulkan-drivers va-driver-all vainfo hwinfo clinfo mesa-utils
According to this statement, the 6.8.0.45 kernel should be supported on a default Ubuntu Server 24.04 LTS installation
"Starting with Ubuntu Desktop* 23.04, the full range of Intel® client GPUs is expected to work with the default Ubuntu installation, except for GPU debugging features"
I could use some advice on how to troubleshoot further as I am unable to use the A380 in my VM for transcoding tasks until this gets resolved. Please advise, thanks!
trademarkej
Ok, so I was able to resolve my issue by re-creating my VM, installing the hwe enabled kernel and adding the intel_arc_a380.bin romfile to my hardware configuration in Proxmox. After a reboot, I can confirm that the i915 drivers were loading correctly.
sudo apt install  -y --install-suggests  linux-generic-hwe-24.04
Earl_Intel
Hi trademarkej,
Thank you for posting on the community!
We are happy to know that the issue for your Intel Arc A380 drivers is already resolved!
With that being said, I will no longer monitor this thread, if you have additional questions or issue, you can create a new thread for us to address your concerns.
Earl E.
