23097 Discussions
Intel Arc A770 16gb bad Performance in New World
KingArtur
like said Performance sucks in New World.
Just changed my Gtx970 for and Acer Predetor Bifrost and have less Fps and a rdc Tearing...
KingArtur
Looks like V-Sync dosent work in New World.
KingArtur
My System ist
I7 6700k
32gb ddr4 3600mhz
Win10 Pro
Fps droped from 40-70 in town to 25-35
Outside of Town 60-100 to 30-60
New World runs on Steam.
Jean_Intel
Hello KingArtur,
Thank you for posting on the Intel️® communities. We understand that you are facing issues when playing New World.
It is important to mention that, based on the Intel® Arc™ A-Series Graphics System Requirements, we recommend using 10th-generation or newer processors.
To have a better understanding of your issue, please provide me with the following:
  • Is  Resizable BAR enabled on your BIOS? Resizable BAR or Smart Access Memory must be enabled for optimal performance in all applications using Intel® Arc™ A-Series Graphics. Refer to your system manufacturer's support page to confirm Resizable BAR support.
  • Share with us a screenshot of the graphics settings you are using.
  • Provide us with a video showing the problem you are experiencing.
  • Create a report using the following tools:
  •  Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello KingArtur,
We hope you are doing fine.
Jean O.
KingArtur
Ye i have to buy new CPU and Board.
Couse gen6 is to old.
Jean_Intel
Hello KingArtur,
Thanks for your response.
As we previously mentioned, we recommend using 10th gen or newer processors for optimal performance when using Intel® Arc™ A-Series Graphics. Additional platforms/motherboards with Resizable BAR / Smart Access Memory enabled may also support Intel® Arc™ A-Series graphics. Refer to your system manufacturer's support page to confirm Resizable BAR support.
Jean O.
Jean_Intel
Hello KingArtur,
We have not heard back from you. So we will close this thread. If you need additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
