Hello, ive been directed here by the LiveChat.
Im searching for Drivers for my SoC, which is put in a Trekstor Surftab Twin 11.6.
The Website for this Chip does not show any Drivers, and there are no archived versions of this driver either, so my last option is for a Intel Employee to look through Intels "Driver Archive" to see if there is a Driver available. To my Knowledge, this thing has a "Intel HD (Cherry Trail)" iGPU, which oftentimes gets compared to the HD5000. After a bit of Research, ive stumbled across the info that Intel Provided the drivers to the manufactorers, and let them modify them to their needs. Since Trekstor is Bankrupt however, i would like to request the drivers, so that i can use them on my Tablet PC.
Hello, i appreciate the effort! Unfortunately this Driver refuses to install, like the rest of the Drivers i have tried (all 15.40 ones). It throws the error "This computer does not meet the minimum requirements for installing this software", i have made sure to use the correct Bit-ness, and for the correct windows version.
Go to device manager -> display adapter -> details -> hardware id
What's your id dev_xxxx ?
The suggested driver supports 22b0 and 22b1
Unfortunately the GPU doesnt seem to appear in the Device Manager, and its running the Microsoft Basic Display Adapter Driver according to DXDIAG.. is there a way to find this out under Linux? The Mesa Drivers under Linux Recognize the GPU and actually use it.
Linux: lspci
Re-check device manager for errors
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller (rev 36) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Subsystem: Intel Corporation Device 7270
Flags: bus master, fast devsel, latency 0, IRQ 153
Memory at 90000000 (64-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
This is what LSPCI regarding anything VGA Spits out. Not sure if this is useful however. I have re-checked Windows, and while yes there were a lot of "Unknown Devices", all of them except for 3 found drivers via a Windows Update Pass. The 3 Remaining Devices are ACPI Devices, not PCI(e) Devices.
