19560 Discussions
Intel Corporation - Display - 26.20.100.7323 wont download and install. Why?
mobitsmobitz
Please help.  See attached.  Thnaks.
AndrewG_Intel
Hello @mobitsmobitz
We understand that you are trying to install "Intel® Graphics driver version 26.20.100.7323" and the system is running Windows* 11. Is this correct?
However, checking the Intel® SSU report, we noticed it is reporting that the Driver Version "26.20.100.7323" is already installed.
Could you please verify if the reported driver version is correct? You may also verify this from Device Manager following these steps:
  • Right-click the Windows Start button. Select Device Manager.
  • Expand the Display adapters section.
  • Identify the Intel Graphics device among the options listed.
  • Right-click the Intel® UHD Graphics 620 device and click on Properties.
  • Click on the Driver tab and look for "Driver Version".
Also, could you please elaborate more on the actual issue/behavior?
1- What do you exactly mean when you said "the driver won't download and install"? For instance:
  • Is it having issues initiating the installation process?
  • Or is it crashing in the middle of the installation process?
  • Does it look like it installs but after reboot the installer shows up again? etc?
Feel free to share some screenshots if it may help to understand better the scenario.
2- The said driver "26.20.100.7323" is not available on the Lenovo* website for Windows 10 and we also noticed it seems they don't offer Graphics drivers for Windows* 11. The only driver we can see they offer is Version 26.20.100.7985 for Windows 10 (64-bit).
In addition, the said driver "26.20.100.7323" is not available on our Download Center either.
Could you please confirm where you are downloading the graphics driver from? Also, please explain the "installation steps that you are following":
Notes:
a- The driver version 26.20.100.7323 is an old version and it seems to not be compatible with Windows 11 and considering the Lenovo website doesn't show a "Windows 11 graphics driver" available, we recommend checking with Lenovo* Support if they have an updated version of the driver (compatible with Windows 11) that is recommended for your system.
This is because Intel® only provides generic drivers and the driver or software for your Intel® component might have been changed or replaced by the computer manufacturer (OEM). The usual recommendation is to use the customized driver from the OEM (in this case, Acer) as the first option so you don’t lose features or customizations. OEM drivers are handpicked and include customized features and solutions to platform-specific issues.
b- If you are not able to find an updated driver from Lenovo* and still you want to update, you can try the latest generic Intel® Graphics DCH Driver version 31.0.101.2111 which is compatible with Windows 11. In case there is an issue installing this driver, you may select the option "Perform a Clean Installation" at the beginning of the installation wizard or manually follow the clean installation steps in this article.
Andrew G.
AndrewG_Intel
Hello mobitsmobitz
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
AndrewG_Intel
Hello mobitsmobitz
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
kakiuchis
In Settings > Windows Update > Downloadable Updates, the following programs do not update successfully.
Can you please tell me how to fix this?
Installation Error - 0x80070103
Please note that the version 26.20.100.7323 is shown in Device Manager > Display Adapters > Intel(R) UHD Graphics 620 > Properties > Drivers.
