22980 Discussions
Intel DSA stuck on scanning
dh351
Hi I have the same issue
The DSA just staying looping on scan
I have uninstalled re installed and i attached the specs,
Could you please check why this is happening its driving me mad!
Thank you
Jean_Intel
Hello dh351,
To have a better understanding of your issue, please provide me with the following:
  • When did the issue start?
  • Which driver are you using?
  • How did you delete the previous Intel® DSA version?
  • Check Intel® DSA service.
    • Ensure the Intel® DSA Service shows a status of Running.
    • In Windows Search, type Services and scroll to find Intel® Driver & Support Assistant.
    • Confirm the Status shows Running; if it isn't running. Then start the service if necessary by right-clicking and choosing Start.
    • Check to see if any Windows* updates are pending.
    • Restart the system.
Jean O.
dh351
The issue started about a month ago, I believe am using the latest driver possible ? How do I check this ?
I have uninstalled it from apps and deleted it from the bin etc completely wiped removed and cleared disk. Then I had reinstalled it. I have tried chrome mozzila and Edge and some other browsers all the same issue on all browsers.
Status is running like normal
All updates are complete as normal
I do not see anything that can stop the system from scanning it seems so strange here !
Jean_Intel
Hello dh351,
The latest version available for the Intel® DSA is version 22.2.14.5.
Since the Intel® DSA scan still isn't working, these are additional steps that can be taken if the Intel® DSA:
  • Clear the browser cache and close the browser.
  • Try rescanning Intel® Driver & Support Assistant (Intel® DSA), ensuring the browser being used is Firefox, Chrome, or Edge Legacy.
Jean O.
Jean_Intel
Hello dh351,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello dh351,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
