23266 Discussions
Intel Driver Assistant recommending Arc driver install? Don't have an Arc card.
Byteus
Intel Driver Assistant is recommending I install the Arc driver however I don't have an Arc card. Didn't see it mentioned in the release notes as anything but an Arc driver however. Is the Arc driver replacing the 770 iGPU driver, which I do have. The revisions look pretty close .3430 vs Arc .3490 as if it would be an update and thus the recommendation. Thought I'd try and confirm first.
Jean_Intel
Hello Byteus,
Regarding your question. The Intel® Arc™ 31.0.101.3490 driver is intended to work with Intel® Arc™ A-Series Graphics. For your 770 iGPU, you should keep using our Intel® Graphics – Windows* DCH Drivers.
To solve this issue where the Intel Driver Assistant is requesting you to install the Intel® Arc™ driver, please, reinstall the Intel® DSA using the Uninstaller tool.
Jean O.
pgaitan
Hello, I have the same problem and uninstalling and re-installing Intel DSA didn´t help.
Please let me know if there is another solution. It's quite annoying.
Pablo
Jean_Intel
Hello Byteus,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello Byteus,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
