22671 Discussions
Intel Driver Update Utility is unable to start because a supporting system service failed to start :S
ABeq
Hello
I am trying to update my Intel, but this is the error message I keep getting when installing.
I have no clue to how to fix this, all this is kind of new to me.
Any help? Thanks in advance.
Windows 10 Home 64-biters
Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
4GB Hyundai 1333MHz
Intel(R) HD Graphics
Realtek High Definition Audio
Stefan3D
source:
Bear in mind that the Intel® Driver Update Utility has been mainly designed for Intel motherboards. We cannot guarantee our utility will be able to work fine on every OEM system. We recommend updating drivers using the utility the computer manufacturer has designed for your computer.
Stefan3D
source:
Hello albanik,
Thank you for contacting the Intel community.
The Intel® Driver update utility might not work properly if you have and OEM (Original Equipment Manufacturer) system like HP.
At this point, I suggest you to download the driver manually, you can download it here:
https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit?product=81502 https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit?product=81502
If you get an error installing this driver you can try installing it manually, please see https://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
Please bear in mind that this processor does not support Windows® 10 and for that reason the driver is available only for Windows® 7 and Windows® 8.
Ivan U.
