22940 Discussions
Intel Graphics 630: Audio drop outs because of slow dxgkrnl.sys
RGraf1
With my brand new motherboard Asus Maximus IX Hero and CPU Intel i7-7700, 3.6 GHz and fresh Windows 10 incl. Creators Update installation
when I listen e.g. to
https://soundcloud.com/pierreghiringhelli/blondie-heart-of-glass-oliver https://soundcloud.com/pierreghiringhelli/blondie-heart-of-glass-oliver
and moving the mouse around, hover links, orange waveform, etc. I have min. 10 audio drop outs and crackles (on this one track) with my professional external audio interface Universal Audio Apollo Twin USB 3.0.
LatencyMon 6.5.1 reports this on my Asus PC:
When I connect the audio interface on my 3.5 year old laptop "Lenovo IdeaPad Y580 i7-3630QM" which has the same fresh Windows 10 installation and settings, I don't have any audio drop outs and "graphics" problems:
System info from my brand new Asus PC:
- OS: Windows 10 Pro, 64bit, Version 1703, 15063.413
- Motherboard: Asus Maximus IX Hero (latest BIOS 0906)
- CPU: Intel i7-7700, 3.6 GHz
- Intel Graphics 630 (Driver 21.20.16.4627)
- External Sound: Apollo Twin USB 3.0 (Driver 9.2)
(connected on one back USB 3.0 on Asus MB)
Of course I've also set and tried in BIOS various settings to avoid audio drop outs
- Intel speed Step => disabled
- Turbo Mode => disabled
- CPU C-States => disabled
- Intel Speed Shift => disabled
- CFG Lock => enabled
Also all possible performance settings in Windows 10 have been done which are recommended by various major music software & hardware companies.
I've also tried
- newer drivers which all didn't solve the problem. Because of another bug (/thread/114464 https://communities.intel.com/thread/114464) I still use build 4627.
- the audio interface on USB ASMedia 3.1 and on PCIE/USB3 card Startech PEXUSB3S44V - no difference.
I've googled around and found another user with a very similar problem - near the same PC hardware as I'm using:
https://superuser.com/questions/1137033/usb-lag-when-mouse-cursor-changes https://superuser.com/questions/1137033/usb-lag-when-mouse-cursor-changes
I've enabled Mouse Properties / Pointer Options / Display Pointer Trails (long) and it has reduced the amount of audio drop outs/crackles to 1-2 instead of 10. Unbelievable why this happens.
Of course it has nothing to do with the mouse driver - I've tried MS default and LogiTech SetPoint driver and the USB connector on all possible connections - no difference.
Finally I was able to avoid the latency problem:
The support from Universal Audio told me to use the new added feature "USB Safety Buffer" (in their latest driver 9.2) which is part of the "USB audio streaming protocol 2.0" which has been added to Windows Creators Update.
http://www.uaudio.com/media/support/downloads/Apollo_Software_Manual_USB_v92.pdf http://www.uaudio.com/media/support/downloads/Apollo_Software_Manual_USB_v92.pdf (search for "Safety Buffer").
I've increased the value from "Minimal" to "Small" and all audio crackles are away.
You might be interested in to search for "USB audio streaming protocol", e.g: http://www.edn.com/design/consumer/4376143/Fundamentals-of-USB-Audio http://www.edn.com/design/consumer/4376143/Fundamentals-of-USB-Audio
Also a very good article if someone is interested: http://allen-heath.helpserve.com/Knowledgebase/Article/View/1002/201/qu-windows-driver-understanding-and-troubleshooting http://allen-heath.helpserve.com/Knowledgebase/Article/View/1002/201/qu-windows-driver-understanding-and-troubleshooting
Finally - the latency problem with this Intel Graphics Driver still exists,
because as far as I understand the Intel graphics driver must return within a specified time (read links above) to MS Direct-x dxgkrnl.sys.
It can't be that on my brand new fast PC I'm having this problem but not on my old Lenovo laptop with same Windows 10 installation.
Other users don't have an expensive audio interface with a superb company like Universal Audio who are updating their drivers - e.g. Native Instruments doesn't support a Windows 10 driver for their Komplete 6 hardware until yet (the audio interface I'd before).
Hello rgIntel,
I understand the Intel graphics driver is causing a latency problem in your computer.
Let me apologize for any inconvenience this issue may be causing to you.
I would like you to try updating the graphics driver. Please download this driver https://downloadmirror.intel.com/26836/eng/win64_154519.4678.exe https://downloadmirror.intel.com/26836/eng/win64_154519.4678.exe
As soon as the graphics driver has been downloaded on the keyboard press WinLogo key + r, then type in devmgmt.msc, double click on Display Adapters -> Intel HD Graphics -> Driver tab -> Uninstall -> Select the check box Delete the driver software for this device -> OK, restart the computer, and then reinstall the driver I provided.
Let me know if issue persists or not.
Fred D.
RGraf1
Hi Fred,
of course - I'd also tried build 4678 (released May 30, 2017) on the date I've reported the problem Jun 27, 2017 - without success.
From my initial message: "I've also tried newer drivers which all didn't solve the problem."
I'm waiting for a newer version - incl. a fix for this /thread/114464 https://communities.intel.com/thread/114464
Robert
Hello rgIntel,
Thanks for the additional information you sent to me.
Would you please fill out the form that is in the following link and post it on this forum thread? /thread/77761 https://communities.intel.com/thread/77761
Please also attach the Intel® System Support Utility, DxDiag and DispDiag reports. The steps to generate the files are on the same forum thread.
Fred D.
RGraf1
Here it is:
Note: Personally for me it is not important because the latest driver from this audio interface I'm using has the brand new option to increase special USB audio buffer which supports the new USB Audio protocol 2.0 added in Windows Creators Update.
However - the graphics card driver partially takes too long to reply against the standard specification and USB audio buffer under run occurs.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
See initial message - perfectly clean explained.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%)
Brand and Model of the system.
Intel Graphics 630 (Driver 21.20.16.4627 - tried up to build 4678)
External Sound: Apollo Twin USB 3.0 (Driver 9.2) - connected on one back USB 3.0 on Asus MB
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
<p style="margin-bottom: 0.0001pt; font-weight: inherit; font-st...
Hello rgIntel,
I will review the information and then I will post on this forum thread the next step.
Fred D.
RGraf1
Hi Fred,
I want to let you know that I just tested the new driver 22.20.16.4729!
No audio drop outs anymore with USB Safety Buffer "Minimal" (Default) settings!
I don't know what you have done or what was the internal problem. I've read the release notes - but ...? However, maybe you might know it.
Screen shot:
I've listen to the Soundcloud file (link at initial message) two times and these are the max. values.
At the moment it looks like the problem has been fixed (automatically).
Hello rgIntel,
I am glad to hear the issue has been fixed. Do not hesitate to contact us back if you have any other inquiry.
Fred D.
