23091 Discussions
Intel HD 3000 ; Unable to recover from sleep
Currently running dual monitors, main monitor on primary 570 and secondary running off of the CPU GPU (3000 HD). For some reason when the computer recovers from sleep the 3000 will not come back on. Other then restarting the computer, the only way I can get video back is to go into device manager, disable the on CPU video then re enable it, then it works fine. No idea why, any ideas?
Intel Driver version. 15.26.12.64.2761
Nvidia Driver version. 301.42
Windows 7 Pro 64-bit
Current setup:
i7 2600k
Asus P8Z68-VGEN3
SLI (2) EVGA Geforce GTX570
Corsair 1kw PSU
Raid 0 (2)WDC VR 150gb
60gb OCZ Agility 3 (drive caching)
Marcos_U_Intel
The combination of a video card and the Intel integrated graphics controller is not supported by the Intel generic graphics drivers from the Intel website, so is possible when the computer recovers from sleep the Intel graphics controller will not come back on because of the drivers you are currently using.
To solve your issue I recommend to use the graphics drivers provided by your computer manufacturer.
Also for more information go to the link below:
http://www.intel.com/support/graphics/sb/CS-031103.htm http://www.intel.com/support/graphics/sb/CS-031103.htm
Michael
Kenny,
I have the exact same problem. I want to use the integrated video to output to my TV when I want to watch full screen video. I found the enable/disable way to fix it for the time being but was hoping there was another fix. I use a high performance video card for video games on my main monitor.
michael - My manufacturer Gigabyte (GA-Z77MX-D3H) is the one that told me to install the intel video driver (Intel HD Graphics 3000). Why isn't this supported? Doesn't see too difficult to just automatically reset the driver when waking from sleep.
Nick
Marcos_U_Intel
Bear in mind our graphics drivers are generic and are not meant to work with Lucid Virtu in a third party motherboard (Gigabyte). The graphics drivers provided by your motherboard manufacturer must be use if you want to use Lucid Virtut in your system.
Michael
