22946 Discussions
Intel HD 3000 Windows 8.1 (x64) and WINSAT D3D -dx10 test
I have a problem with winsat test in windows 8.1 (x64). It skips d3d dx10 test. I also get this error message in winsat.log "Driver is not WDDM 1.1 or WDDM 1.2; aborting DX10 assessment" . Here are my log files. Please I hope that you can find a solution.
Hardware info: (msinfo32.exe)
Windows 8.1 Pro 6.3.9600
Hardware Abstraction Layer Version = "6.3.9600.17196"
Intel HD graphics 3000
PNP Device ID PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09\3&21436425&0&10
Installed Drivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver Version 9.17.10.4229
INF File oem46.inf (iSNBM0 section)
Resolution 1600 x 900 x 50 hertz
Memory Address 0xA0000000-0xA03FFFFF
Memory Address 0x90000000-0x9FFFFFFF
I/O Port 0x00005000-0x0000503F
IRQ Channel IRQ 4294967292
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\igdkmd64.sys (9.17.10.4229, 5.13 MB (5,384,176 bytes), 01/06/2015 22:00)
winsat d3d -dx10 (part of formal.assessment (initial).winsat.xml)
DXVersion="9">240.17999
DXVersion="9">236.21001
DXVersion="9">79.38000
DXVersion="9">72.56000
DXVersion="10">0.00000
Here is the result of runing winsat d3d -dx10 commad (or winsat prepop or winsat formal)
Here is the winsat.log
49316765 (1072) - exe\logging.cpp:0841: --- START 2016\1\6 18:38:46 ---
49316765 (1072) - exe\main.cpp:4511: WinSAT registry node is created or present
49316765 (1072) - exe\main.cpp:4542: Command Line = winsat d3d -dx10
49316765 (1072) - exe\main.cpp:4314: INFO: The axe results path environment variable is not set. Assuming we aren't running under AXE.
49316765 (1072) - exe\main.cpp:4649: INFO: Winsat is not running in AXE mode.
49316765 (1072) - exe\processwinsaterror.cpp:0146: ERROR: tried to read resource strings, unknown exception occured
49316781 (1072) - exe\main.cpp:2615: > DWM Running.
49316781 (1072) - exe\main.cpp:2622: > turning off DWM.
49316781 (1072) - exe\syspowertools.cpp:0983: > Read the active power scheme as '8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
49316781 (1072) - exe\main.cpp:2923: > power policy saved.
49316828 (1072) - exe\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
49316828 (1072) - exe\main.cpp:2944: > power policy set to maximum.
49317093 (1072) - exe\main.cpp:0867: > WinSAT info: Version=V6.3 Build-9600.17415
49317109 (1072) - exe\main.cpp:1007: > IsOfficial=TRUE IsFormal=FALSE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
49317109 (1072) - exe\main.cpp:4125: > Power 'execution' request successfully set.
49317109 (1072) - exe\main.cpp:1852: > Run Assessment features
49317109 (1072) - common\winsatutilities.cpp:1060: PNPID from DX9 call = PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
49317109 (1072) - common\winsatutilities.cpp:1126: Index [0]: PNPID = PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
49317109 (1072) - common\winsatutilities.cpp:1150: Matching device PnPID is PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
49317109 (1072) - common\winsatutilities.cpp:1126: Index [1]: PNPID = ROOT\BasicDisplay
49317109 (1072) - exe\main.cpp:1852: > Run Assessment d3d -dx10 -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
49317109 (1072) - d3d\graphicsop.cpp:0195: GraphicsOp::AssessmentThread Launched with priority 0
49317109 (1072) - d3d\graphicsop.cpp:0217: Driver is not WDDM 1.1 or WDDM 1.2; aborting DX10 assessment.
49317109 (1072) - exe\main.cpp:1852: > Run Assessment d3d -dx10 -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
49317109 (1072) - exe\main.cpp:1852: > Run Assessment d3d -dx10 -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
49317109 (1072) - exe\main.cpp:1852: > Run Assessment d3d -dx10 -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
49317125 (1072) - exe\main.cpp:1852: > Run Assessment d3d -dx10 -aname GeomF4 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 150;200;241 -batchcnt C(50);C(200);C(300) -objs C(12);C(26);C(45) -noalpha -geomf4shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
49317125 (1072) - d3d\graphicsop.cpp:0195: GraphicsOp::AssessmentThread Launched with priority 0
49317125 (1072) - d3d\graphicsop.cpp:0217: Driver is not WDDM 1.1 or WDDM 1.2; aborting DX10 assessment.
49317125 (1072) - exe\main.cpp:1852: > Run Assessment d3d -dx10 -aname GeomV8 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75;100;120 -batchcnt C(25);C(100);C(150) -objs C(8);C(17);C(29) -noalpha -geomv8shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime...
Amy_C_Intel
Hello, palmiris:
We have not received cases like the one that you mentioned. However; I found this forum in Microsoft site http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/windows-81-pro-winsat-problems/0d8f8ac2-f361-44f6-bea1-748fe9363f9e?db=5&auth=1 Windows 8.1 Pro - WinSat Problems - Microsoft Community maybe could be helpful.
Amy.
Did you test to verify if same problem exists with all intel HD 3000 graphics and windows 8.1 x64 systems.????? if you don't test how do you know it is not a graphics card driver related problem with windows 8.1 which is Intel's responsibility to provide a fix.?????
I did not have any issues with windows 8.0.
Please report findings.
Your answer does not enclose any relevant evidence if this problem is replicated or not and if yes why and how in order to fix.
Amy_C_Intel
I ran some tests based on your description but the error did not occurred.
Bear in mind that WinSAT is a module of Microsoft this is not related with the Intel® HD Graphics driver, this will help to match the computer hardware performance with the performance requirements of software.
I would recommend contacting Microsoft in order to address this matter https://support.microsoft.com/en-us/contactus?wa=wsignin1.0 Contact Us.
Amy.
Dear Amy,
Thanks for the reply and performing a winsat test. I do appreciate this response.
However
1. It would have helped if you posted the winsat.log and latest Formal.Assessment (Recent).WinSAT.xml so that I can compare. In case you still have it please can I have them for private use (comparison purpose)??
2 I have run a clean boot but without the microsoft services selected. I will select all of them again just to test if a microsoft service is causing this issue.
I will keep you posted if any changes occur, which I doubt. I have all latest bios- chipset driver and all other hardware drivers are the newest and all recognised. I am at a dead end. I am thinking of downgrading as a last option..
Panayiotis
Amy,
I have uninstalled antivirus I have disabled all start-up programs, I have disabled all services including those of Microsoft except power service which is needed and winsat d3d -dx10 still skips the test.
Clean boot does not work either. So it is not a service or a program interference I reckon.
Any suggestions????
If winsat cannot run the test is it because the driver is missing a feature which is not enabled in order to run the winsat d3d -dx10 test?? ???? It is something wrong with windows 8.1 which is wddm 1.3 but intel hd 3000 driver is legacy under windows 8.1 since it is using a wddm 1.2 driver as intel failed to develop the driver to fully support windows 8.1???? It is never late to create a wddm 1.3 driver to fully support windows 8.1 and correct issues caused with incompatibilities. Most features are working including widi. You just have to copy intel hd 4000 graphics card driver (except the direct X features) and create the intel hd 3000 wddm 1.3 driver.
If you have an intel hd 3000 driver under production / beta I am willing to test.
Panayiotis
Request
Please bring this request for further developing intel hd 3000 in order to fully support windows 8.1 or windows 10 or both (wddm 1.3 and or wddm 2.0) to the attention of the management.
Amy_C_Intel
I have tested this behavior on Windows® 8.1 and Intel® HD Graphics 3000 including the latest drivers and the issue did not occurred.
The latest driver available for this graphics controller is 4229, at the moment we do not have information that Intel will be developing more drivers for Intel® HD Graphics 3000 for Windows 8.1. In regard to Windows 10, this graphics controller does not support this operating system, note the picture below;
With Windows® 10 and Intel® HD Graphics 3000 there are no plans no develop new driver, however you should be able to find driver through Windows Updates.
Let me try to test this one more time but this time guide me in how to reproduce this; please include all the steps that you are following to run this test, feel free to add all details you want.
Amy.
Dear Amy,
in windows 8.1 x64 there is no WEI benchmark app. It was removed. However you can run the same test on command mode (cmd.exe) as administrator.
in command mode write
winsat d3d
or
(winsat d3d -dx10)
the dx9 tests run fine
the dx10 tests are skipped since they don't display a value other than 0.
winsat.log and Formal.Assessment (Recent).WinSAT.xml are found in windows/perormance directory
Also when reading winsat.log you will observe the following"Driver is not WDDM 1.1 or WDDM 1.2; aborting DX10 assessment , next to d3d dx10 test. (check my winsat log)
From winsat.log
396250 (6816) - d3d\graphicsop.cpp:0217: Driver is not WDDM 1.1 or WDDM 1.2; aborting DX10 assessment.
396250 (6816) - exe\main.cpp:4164: > Power request 'execution' successfully cleared.
396265 (6816) - exe\processresults.cpp:1547: No D3D10 Subscore. Using D3D9 subscore for final D3D score.
132609 (8180) - common\winsatutilities.cpp:1060: PNPID from DX9 call = PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
132609 (8180) - common\winsatutilities.cpp:1126: Index [0]: PNPID = PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
132609 (8180) - common\winsatutilities.cpp:1150: Matching device PnPID is PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
132609 (8180) - common\winsatutilities.cpp:1126: Index [1]: PNPID = ROOT\BasicDisplay
Why PNPID = ROOT\Basic Display??????????????????????????????????????
there is no call for PNPID from DX10 call why?????????????
Please test as above.
Do you think the problem is in this registry where basic display is set?????? or any other setting which is installed wrongly by the driver??? Here are the registry current display settings: Do you think it is easy to have a look? Something with device 0 is not correct igfx is calling it intel hd 3000 whereas it is also a basic display registry too. Thanks
[HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\VIDEO]
"\\Device\\Video0"="\\Registry\\Machine\\System\\CurrentControlSet\\Control\\Video\\{0AA4DC11-7E28-4708-8B59-2C1D6B3D6C6D}\\0000"
"MaxObjectNumber"=dword:00000002
"ObjectNumberList"=hex:00,00,00,00,01,00,00,00,02,00,00,00
"\\Device\\Video1"="\\Registry\\Machine\\System\\CurrentControlSet\\Control\\Video\\{0AA4DC11-7E28-4708-8B59-2C1D6B3D6C6D}\\0001"
"\\Device\\Video2"="\\REGISTRY\\MACHINE\\SYSTEM\\ControlSet001\\Services\\BasicDisplay"
"\\Device\\Disc"="\\REGISTRY\\Machine\\System\\CurrentControlSet\\Services\\TSDDD\\Device0"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicDisplay]
"ImagePath"=hex(2):5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
74,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,64,00,72,\
00,69,00,76,00,65,00,72,00,73,00,5c,00,42,00,61,00,73,00,69,00,63,00,44,00,\
69,00,73,00,70,00,6c,00,61,00,79,00,2e,00,73,00,79,00,73,00,00,00
"Type"=dword:00000001
"Start"=dword:00000001
"ErrorControl"=dword:00000000
"Group"="Video"
"Tag"=dword:00000004
"Owners"=hex(7):64,00,69,00,73,00,70,00,6c,00,61,00,79,00,2e,00,69,00,6e,00,66,\
00,00,00,62,00,61,00,73,00,69,00,63,00,64,00,69,00,73,00,70,00,6c,00,61,00,\
79,00,2e,00,69,00,6e,00,66,00,00,00,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicDisplay\Device0]
"Device Description"="Microsoft Basic Display Adapter"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicDisplay\Video]
"Service"="BasicDisplay"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicDisplay\Enum]
"0"="ROOT\\BasicDisplay\\0000"
"Count"=dword:00000001
"NextInstance"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicDisplay\VolatileSettings]
"{5b45201d-f2f2-4f3b-85bb-30ff1f953599}"=hex:5c,00,3f,00,3f,00,5c,00,52,00,4f,\
00,4f,00,54,00,23,00,42,00,61,00,73,00,69,00,63,00,44,00,69,00,73,00,70,00,\
6c,00,61,00,79,00,23,00,30,00,30,00,30,00,30,00,23,00,7b,00,35,00,62,00,34,\
00,35,00,32,00,30,00,31,00,64,00,2d,00,66,00,32,00,66,00,32,00,2d,00,34,00,\
66,00,33,00,62,00,2d,00,38,00,35,00,62,00,62,00,2d,00,33,00,30,00,66,00,66,\
00,31,00,66,00,39,00,35,00,33,00,35,00,39,00,39,00,7d,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicRender]
00,69,00,76,00,65,00,72,00,73,00,5c,00,42,00,61,00,73,00,69,00,63,00,52,00,\
65,00,6e,00,64,00,65,00,72,00,2e,00,73,00,79,00,73,00,00,00
"Group"="Video"
"Tag"=dword:00000003
"Owners"=hex(7):62,00,61,00,73,00,69,00,63,00,72,00,65,00,6e,00,64,00,65,00,72,\
00,2e,00,69,...
Amy_C_Intel
Thank you for the information.
Please include dxdiag report, in the "Run" window, type "dxdiag" and click OK. A "DirectX Diagnostic Tool" window should pop up. In the window that has now appeared choose "Save all information" After you've saved the file, please attach here.
I would also like to know, what is the purpose of running this test? What are you trying to get from it?
Hello Amy,
I am testing intel hd 3000 (2nd gen i5-2520m) in windows 8.1 to see if it a good upgrade option from windows 8.0 (previous I had windows 7.0). So my tests are to see if:
1. graphics related performance of intel hd 3000 in windows 8.1 is similar to windows 8.0
2. All graphics related performance tests are run successfully
3. there are no driver issues with compatibility mode as windows 8.1 is wddm 1.3 and intel hd 3000 driver is 1.2
4. widi is working as good as windows 8.0
For the moment I have two problems:
1. 2D graphics (desktop) performance test is lower in Windows 8.1 than windows 8.0 (20%) (also tested with passmark performance test)
2 Winsat test skips run d3d -dx10 test
DxDiag.txt file as requested.
Panayiotis
System Information
Time of this report: 1/18/2016, 21:14:48
Machine name: T420_4236_B87
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_ltsb.151230-0600)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 4236B87
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 8192MB RAM
Available OS Memory: 8012MB RAM
Page File: 2335MB used, 6955MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.17415 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_21CE17AA&REV_09
Display Memory: 1760 MB
Dedicated Memory: 128 MB
Shared Memory: 1632 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: LCD 1600x900
Monitor Model: unknown
Monitor Id: LEN40A1
Native Mode: 1600 x 900(p) (60.020Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.4229 (English)
Driver Version: 9.17.10.4229
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 5/26/2015 21:00:24, 12694808 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4266-11CF-9F64-C401B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0126
SubSys ID: 0x21CE17AA
Revision ID: 0x0009
Driver Strong Name: oem47.inf:5f63e534992ddd9e:iSNBM0:9.17.10.4229:pci\ven_8086&dev_0126
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=...
Amy I am double posting this at intel web site
latest hd3000 drivers not WDDM1.3 for Windows 8.1 - DX10 assessment 0 in WEI
created by Cesar Badilla in Graphics - /message/366674# 366674 View the full discussion
I think I may have identified a problem.
1. I have a june 2010 directX installation on my laptop which I cannot unistall for the moment.
2. I may have installed Mar09 redistribution before the june 2010 directX redistribution
3. I did find the following registry entry
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectX]
"Version"="4.09.00.0904"
"InstalledVersion"=hex:00,00,00,09,00,00,00,00
"MinFeatureLevel"=dword:0000a100 (41216)
"MaxFeatureLevel"=dword:0000a100 (41216)
"SDKVersion"="9.29.1962.0"
The registry maybe forcing directX 9.0
So I think my registry must be corrupt with directX 9.0 even though sfc /scannow does not recognise an error and chkdsk /r does not recognise an error.
continuation
I have uninstalled all previous directX drivers (by reinstalling and uninstalling since I could not remove it).
Still same problem remains. I have reinstalled intel hd 3000 latest intel driver. Still the problem remains.
Did you manage to recreate the issue by any chance??? Is it a driver problem with windows 8.1 due to compatibility mode driver installation.??? (Windows 8.1 is wddm 1.3 whereas intel hd 3000 driver is wddm 1.2)
Ok I have identified the problem.
This information is missing from dxdiag
BIOS: 83ET76WW (1.46 )
Windows 8.0 which I have just installed has it.
here is the dxdiag from windows 8.0 as a comparison with my previous post.
System Information
Time of this report: 1/22/2016, 18:47:36
Machine name: T420-4236-B87
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_rtm.120725-1247)
Language: Greek (Regional Setting: Greek)
Memory: 8192MB RAM
Page File: 2255MB used, 10364MB available
Windows Dir: C:\Windows
User DPI Setting: Using System DPI
DxDiag Version: 6.02.9200.16384 64bit Unicode
This makes me believe that an upgrade from windows 7.0 is not the correct way to install windows 8.1. A clean installation is probably the best way otherwise problems arise with direct3D -dx10.
I will not install windows 8.1 as windows 8.0 is probably the best operating system for the intel hd 3000.
I dont think that it is a driver problem.
It is either:
1. an installation upgrade bug. A clean installation is needed (advanced installation by deleting all locations in order for the system to create new installation locations)
2. A bios incompatibility with windows 8.1
Intels driver is working fine.
Sorry for the trouble.
Amy_C_Intel
palmiris, Thank you for your feedback. I am glad to hear that you were able to identified this issue. I am sure that this post will help other users with similar issues.
Here is the WEI score under Windows 8. It rocks.
I recommend for people who update windows 7 to windows 8.1 to do a clean installation. Just to make sure check the winsat d3d -dx10. If this test fails do a clean installation and if this still persists ask for a windows 8.1 bios compatible update.
This thread I assume it is now answered. I agree that many users have this problem. I hope this thread is helpful to them too.
Panayiotis
