20842 Discussions
Intel HD 4600 Driver Error, PC doesn't meet minimum requirements
JReis7
I have a i5 4460 in a motherboard h81 gamer asus
I can´t use the grafics card because dont apear because i dont have the drive and appear that mensage
Instead I can recognize my GTX 960 , i dont understand
JReis7
Please help !
Stefan3D
Configure graphics in BIOS as described in your motherboard's manual
https://www.asus.com/Motherboards/H81GAMER/HelpDesk_Manual/
n_scott_pearson
When you insert an add-in graphics card (like this GTX 960) into a desktop motherboard, the BIOS, by default, will disable the Intel HD Graphics engine. If you would like to use BOTH the GTX 960 and the Intel HD Graphics engine, you need to go into BIOS Setup and configure it so that the Intel HD Graphics engine is not disabled. This is usually a parameter that you set to Auto, Primary or Secondary (your's may be different; I do not know what your motherboard's BIOS looks like).
