23089 Discussions
Intel HD 4600 Driver Error, PC doesn't meet minimum requirements
rambomhtri
New Contributor II
Hi, this is actually the second or third time this happens to me. I have a notebook Lenovo Y510P, Intel i7-4700MQ with Intel HD 4600, Intel HM86 MoBo and Windows 8.1 x64. When I download the latest drivers for my HD 4600, which are "win64_154034.4624", after the unzipping completes, this error occurs:
ERROR: This computer does not meet the minimum requirements for installing the software
I'm downloading the correct drivers for my Intel HD 4600, tried several times, but still stuck with this error. I remember this has happened to me in the past 1 or 2 times. By the way, right now I have installed the previous drivers 10.18.14.4578.
Please, fix it, I don't get why a non functioning driver is released.
Hello rambomhtri,
I understand you are trying to install latest graphics driver, but the installation fails.
Let me apologize for any inconvenience this issue may be causing to you.
I would like you to try installing the graphics driver manually. Please download this driver https://downloadmirror.intel.com/26682/eng/win64_154034.4624.zip https://downloadmirror.intel.com/26682/eng/win64_154034.4624.zip
Please install that driver with the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Let me know if issue persists or not.
Fred
rambomhtri
New Contributor II
OK, I'm gonna try that (I'm pretty sure I've tried that in the past when this issue happened and couldn't install it), but anyway, in the first place, the exe file should totally work as all the rest of exe drivers before.
EDIT: I've just done it and after selecting the inf file, in all the graphic card names that appear, there's not there the HD 4600. So this is great, you upload a driver for a HD 4600 that is not compatible with the HD 4600. This has happened already twice in the past. Cool!
Hello rambomhtri,
After checking the Release Notes of that specific driver I found out that on 4th Generation Intel Core processors the driver will install on Windows 10* only. I apologize for any inconvenience.
What are you trying to update graphics driver for? Are you having a specific graphics issue in the computer?
Fred
rambomhtri
New Contributor II
Nothing in particular, just for the sake of having the latest version, which is always optimal.
But if you ask me, I've noticed that AFTER the driver "win64_153626.4294", the right click menu in the Windows 8 Start Screen is tiny. This bug has been there since October 2015, and Intel still has not fixed it. I did't create a thread here because it was something I didn't use (Windows Start Screen) and because I thought you were going to fix it in the next release, may be January 2016 or something, but I was wrong. If you could look it up it would be nice.
