I don't know why the intel graphic card doesn't appear in the device manager. Even it is integrated in the motherboard. I installed all the windows updates and nothing happened. Also when I want to install intel drivers they tell me "this computer does not meet minimum requirements".
I will so happy if you can solve my problem sooner. Thank you in advance 🙏
By the way these are my computer characteristics:
*Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.20 GHz
*Hp
*Windows 10
*Double graphic cards : Intel HD 530 + Nvidia Nvs 310
*16 Go RAM
Is this a Desktop design? In Desktop designs, the default is to automatically disable the Intel graphics engine if an add-in graphics card is detected. If you want both engines to be enabled (because you are using enough monitors that the connectors on the add-in graphics card are exhausted), there is usually a place in BIOS Setup where you can configure that the Intel graphics engine be enabled always.
Hope this helps,
Yes it is a Desktop.
Thank you so much for explaining the reason why it doesn't appear.
And yes Sir. That's the solution I am looking for. If you can refer me to a video or website where I can see the BIOS Setup where I can configure that the Intel graphics engine be enabled always that's will be so helpful.
Thank you so much.
Sorry, without having your particular motherboard in front of me, I cannot tell you how to navigate to this parameter. This should be explained in the BIOS Settings section of your motherboard/system User's Manual. If not, you'll have to contact the motherboard manufacturer.
Can these information help you to find a solution for me.
My computer desktop is :
HP Z240 Small Form Factor Workstation
The version of BIOS is version 1.19.0.0
As I said, I would have to have one in front of me. I can't help you without having one. You will need to contact HP and ask them.
Okey Sir thank you for your time and your advices. I really appreciate that.
