20623 Discussions
Intel HD 530 works with 4k@60Hz but no audio
DInic
As title says, I have an i7 6700k (HD 530) processor, which works fine at 4k@60Hz using HDMI, but I must disable Intel Display Audio from Device Manager otherwise it starts to flicker really bad and sometimes also crashes my system.
By lowering the refresh rate and keeping it at 4k@30Hz I can successfully enable the HDMI audio and everything works good, except for the fact that @30Hz is unsable.
Hello dominict,
I understand that you are having problems with the graphics and the audio.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
Hello dominict,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
