20626 Discussions
Intel HD 5500 - Quake Champions - Texture flickering
OSkyr1
Is there any solution that fixes flickering on Intel HD 5500 in Quake Champions ?
Here you can see what I mean (by the flickering): https://www.youtube.com/watch?v=uUVC7XRtcT0
BTW: The game actually runs way better than on this video, but the flickering is really bad.
Hello IMP700,
Thank you for joining this Intel Community.
Because gaming performance may vary depending on hardware, software and game configuration, we would like to get more information to address this issue correctly.
It will be helpful if you could attach a video of the flickering the game experiencies when you play. Please attach pictures of the game configuration, too.
Keep in mind that it is recommended to have the graphics driver up to date. Have you tried updating the graphics driver?
Also, please run the Intel® System Support Utility and attach the report to take a look at your system configuration.
1.Download the Intel® System Support Utility and save the application to your system.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View.
3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
Wanner G.
OSkyr1
Hello Wanner,
As you can see on this video (not recorded by me): https://www.youtube.com/watch%3Fv%3DuUVC7XRtcT0 https://www.youtube.com/watch?v=uUVC7XRtcT0 he is having the same issue, it happens on any video settings.
All my drivers should be updated. And for the GPU I use Intel® Graphics Driver v15.40.38.4963 (should be the official latest)
The log from Intel® System Support Utility is attached.
BTW on the Intel HD 4000 it works fine without any glitches: https://www.youtube.com/watch?v=UA7nyLYBUiQ Quake Champions beta "running" on intel HD 4000 - YouTube
Thanks for your help!
RonaldM_Intel
Hi IMP700,
Can you check if the issue persist after enabling V-Sync within the game settings?
Ronald M.
OSkyr1
Yes, still the same even in window mode.
Hello IMP700,
Thank you for your reply.
We will do further research about this issue.
Wanner G.
Hello IMP700,
I am still doing research about this issue and I was checking the report attached.
This is your system model:
-HP ProBook 430 G2
SKU: K3R10AV
According to the support website, there are AMD Video Drivers available for your computer. Does this model have discrete graphics, too? I could not find this information on the report attached.
If it does, could you please let me know if texture flickering occurs using the discrete graphics?
Also, does this model come with Windows* 7 or Windows* 8.1?
Wanner G.
Under Contract to Intel Corporation
OSkyr1
this model actually has only the Intel HD 5500 GPU and by default there were windows 8, but I use windows 10.
Also I have increased the RAM from 4GB to 16GB.
Hello IMP700,
We will get back to you soon.
Wanner G.
Hello IMP700,
I am writing to let you know that we are still working on providing more information about this issue.
Wanner G.
Hello IMP700,
I am writing to let you know that we were able to replicate the issue reported when playing Quake Champions. We have been testing the game with a system that uses the same graphics controller, Intel® HD Graphics 5500, and these graphics driver versions:
A. Version: 15.40.41.5058 (Latest)
B. Version: 15.40.38.4963.
We also tested the game on a Dell XPS™ 15 9530 with Intel® HD Graphics 4600 / GeForce GT 750M. However, we did not run into any issues on this system.
You also mentioned that the texture flickering does not occur if you use a system with Intel® HD Graphics 4000. Do you have more information about this system? (e.g OS, System model)
Please run the Intel® System Support Utility if possible.
Wanner G.
OSkyr1
Hello Wanner,
I currently don't have access to the computer with Intel HD 4000, but both computers have the same OS Windows 10 64-bit, 8+ GB RAM, Intel Core i5.
Thank you for your help.
Hello IMP700,
Thank you for your response.
As soon as we have an update about this issue, I will get back to you.
Wanner G.
Hello IMP700,
Please fill out the following information and attach the reports:
/thread/77761 Information for reporting Graphics issues
-Intel® System Support Utility report (in case of OS changes)
-DxDiag* report.
-DispDiag report
Wanner G.
Hello IMP700,
We would like to gather the information requested above to continue working on this issue.
Wanner G.
MOlwa
Hello, have a same problem on my X1 Carbon 3rd gen
I7 5600U
HD 5500
8 ram
SSD
Hello Olwaht,
If you are experiencing the same issue with Quake Champions, please fill out the following information and attach the reports:
-DxDiag* report.
-DispDiag report
Wanner G.
MOlwa
Hello
Thank you for helping with our problem
All files in attachments
regards
Hello Olwaht,
We will get back to you as soon as possible.
Wanner G.
Hello all,
I am writing to let you know that, based on further research, Quake Champions is not compatible with 5th Generation graphics. In other words, you may experience some issues including texture flickering.
It is worth mentioning that your feedback is highly appreciated and it will help us improve. However, we cannot promise that a fix will be available anytime soon.
We also recommend you to check out our https://gameplay.intel.com/ to optimize your games to play on Intel® Graphics.
Quake Champions
  • Intel® Core™ i5-5200U Processor
https://gameplay.intel.com/en-us/PromoPage/Index/662046/i55200u/1/3 Intel® HD Graphics 5500
  • Intel® Core™ i7-5600U Processor
https://gameplay.intel.com/en-us/PromoPage/Index/662046/i75600u/1/3 Intel® HD Graphics 5500
Wanner G.
