I was using Nvidia 1080TI and was working fine and now I've switched to the Intel HD 630 from the 8600k processor.
In Intel Graphics Command Center I can't set more than 60hz, in Information tab I can see it supports 144hz, same resolution and hz that I was using before with 1080TI.
1920x1080 @ 144hz @DVI
Why is this happening, and what can I do? I use DVI cable and it used to work fine on Nvidia card.
Thank you
The BenQ XL2411Z monitor basically supports 1080p @ 144 Hz. According to the information in the manual, however, it only seems to support it via DVI-D Dual Link.
Please state which computer (manufacturer and model) you are using. Alternatively, the manufacturer and model of the motherboard on which the processor is installed. If the computer does not have a DVI-D Dual Link port, which adapter cable are you using?
Please run the Intel System Support Utility (SSU) for Windows with all options and attach the export file here. Please generate a Report for Intel Graphics Drivers as well and attach it here.
