My system is
CPU intel I5-7400 @ 3GHz
8Gb RAM
Win 10 x64
video onboard HD 630
I have the latest drivers installed - march 2019 version
I use one display on VGA- works fine.
I need one secondary display on HDMI.
From bios I enabled Multi display as required
Still there is no signal getting to the monitor-TV and the Intel utility does not detect any other display except the primary.
the mobo is new just bought it last november.
how to tell if the fault if from the display , the hdmi port or the mobo?
help please I am left out of options
many thanks
Glad you found the problem!
By marking this thread as "best answer", that will close the thread so that no other responses can be made.
Doc
Can you try a different hdmi cable?
Doc
did proved. Forgot to write it.
Another detail: hdmi toi DVI- I also have such connection cable- DVI on Mobo not workin also- is not recognizing display.
What I did:
I have 2 display
One Acer and one LG
Acer is only VGA
LG is VGA, HDMI
I have 2 cables
hdmi to HDMI
and
HDMI to DVI
The LG has been tested on another computer on HDMI and works
The HDMI to HDMI cable was tested with the monitor in another pc I own- works fine
The HDMI to DVI cable works the same tested the same
When I try to connect the LG display as secondary to my Intel hd 630, with the Acer on VGA as primary- LG on HDMI fails, also Fails using hdmi to dvi.
I use latest drivers- tested also with the tool Intel provides.
I enabled the multi in bios setting the output on vid onboard chipset ( was auto but better to be precise)
Is it possible that no other port works except vga on a brand new mobo???
Update:
After moving and pushing the connector against the pc case I found the guilty piece: The case - it keeps the connectors about 2 to 3 mm out due to the mobo being a bit more inside then normal. At this point obviously the vga , that is less sensible is acting fine but dvi and hdmi suffer. I had the metal plate on the back of the case removed and now connectors can be reached fine.
Sorry for the fuss. But this can also be help full to everyone that never thought of checking the depth the connectors run .
Admin can you please close the topic?
regards
Antonia
Doc
