22860 Discussions
Intel HD Graphics 3000 black screen on restart (Windows 8.1 x64)
VDimi1
I tried to install Windows 8.1 on my laptop but I encountered the following problem:
After the installation and setup everything worked fine but when I installed Intel HD Graphics 3000 the display closed and ever since, whenever I restart my laptop the screen is black.
Remarks:
  1. When I shutdown and then open the laptop everything works fine.
  2. When I restart the laptop the screen is black after windows logo.
  3. If I connect an external screen everything works fine.
  4. If after the restart I press power button to put laptop to sleep and then wake it up after 5 seconds, screen opens and everything works fine.
  5. The problem only occurs with Windows 8.1. I tested with windows 7 and there is no problem.
  6. I installed the latest drivers for hd graphics from your website.
  7. When I disable Intel graphics driver everything works normal but of course graphics are downgraded so that is not really a solution.
I also tried to update BIOS but I did not do it after all because I could not find an update for my motherboard.
Information:
CPU:
Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
Motherboard:
Manufacturer: Pegatron Corporation
Model: A15
BIOS:
Brand: American Megatrends Inc.
Version: 300
Date: 12/22/2011
