Community
cancel
Showing results for
Search instead for
Did you mean:
Intel® HD Graphics 3000 doesn`y recognize second monitor on thunderbolt port (mini displayport)
Hi, I've a Macbook pro Late 2011 with Windows 10 1903 (Nov2019). The trouble is that I cant make that the mini displayport detect the Monitor.
if I swith to Mac os, the monitor runs ok.
With a previous version of Windows 10 I can make it running, .
Can anyone give some help? o what can I do ??
I'm using the intel update drivers
I've installed the bootCamp 5 drivers installed
Actual driver version
Intel(R) HD Graphics 3000
Report Date: 12/12/2019
Report Time[hh:mm:ss]: 20:34:41
Driver Version: 9.17.10.4459
Operating System: Microsoft Windows 10 Enterprise(10.0.18363)
Default Language: English (United States)
DirectX* Version: 11.0
Physical Memory: 16296 MB
Processor: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz
Processor Speed: 2395 MHz
Vendor ID: 8086
Device ID: 0126
Device Revision: 09
*  Processor Graphics Information  *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2098.0
Current Graphics Mode: 1280 by 800
*  Devices Connected to the Graphics Accelerator  *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 3.55
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 11.42 inches
Vertical: 07.09 inches
Monitor Supported Modes:
1280 by 800 (58 Hz)
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 36 7F 03 90 0E 00 00 00
00 0C 01 03 80 1D 12 FF 2F 00 00 A0 57 49 9B 26
10 48 4F 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 52 1C 00 8F 50 20 2E 30 30 20
36 00 1E B3 10 00 00 19 EA 1A 00 A0 50 20 17 30
0C 30 43 00 00 00 00 00 00 1E 00 00 00 FD 00 00
3C 00 E7 08 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0
* Other names and brands are the property of their respective owners. *
Your HD3000 graphics are not supported on WIndows 10. You are using the Microsoft generic driver which is lacking in features and functionality. There is no updated intel driver.
For more support, contact apple.
Doc
Hi Al.Hill
Thanks a lot !!, But I've make it running ok with a previous version/release of "windows 10", so one of the previous version of the driver should be working, The issue start when I need to reinstall "windows 10" . I don`t rememnber which version of drivers were installed or what version/release of windows 10 were on the mac..
I remember that windows 10 were updated from windows 7, and I've similar issues to get it working,
There is only the Microsoft generic driver.
Again, Apple has requested that all questions regarding its platform be directed to apple support.
Doc
