My laptop has an Intel Core i7 3630QM CPU and Nvidia GeForce GT 630M GPU.
The problem is when I disconnect the power supply and the brightness is 100% the backlight starts flickering and doesn't stop until I reconnect the power supply or decrease the brightness.
The Intel driver, Nvidia driver and BIOS are up to date.
I've disabled the "Display power saving technology" but that didn't fix the problem.
連結已複製
Hi maximvd,
Have you tried disabling "display refresh rate switching"? if its enabled it might switch the refresh rate from 60 to 40(or what ever the rate your display hold)while unplugging your power supply which might obviously be the reason behind the flickering. disabling power saving technology has nothing to do with the flickering.
Open the Intel HD Graphics Control Panel. You'll see an option call Power. click on that, and then you'll find these options which is in the image below.
Do you have the latest driver installed? or have you tried reinstalling the driver?what is the refresh rate of your laptop display?
Yes you have the latest driver. Have you checked the display settings under the nvidia control panel since you have a GT 630M?
I could only find one setting which could have something to do with power saving and I set it to max perfomance.
Is there a reason why I cant disable/enable display refresh rate switching?
What refresh rate are you using and what's the refresh rate of your laptop display?If it still doesn't work have you tried reinstalling the driver? and if it still doesn't work do you have the marked setting in the NVidia control panel?
If you are unable to fix it still try these steps
Open regedit (type regedit in start menu search box)
Navigate to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Classes
Now hit Ctrl+F or select find from the edit menu.
Search for: FeatureTestControl
When you find it, change whatever it currently is to f840 (as hex) or 63808(decimal).
Reboot. Now it will stay on 60Hz whether you run on A/C or Batts.
Give me all the details about your pc. including the refresh rate and the makers details.
Here you go, the refresh rate is set to 60Hz but I'm not sure how to detect the actual refresh rate.
Okay, have you tried reducing the refresh rate to 40Hz and see if the problem persists?
If you don't have an option to change the refresh rate like in the image below then the "display refresh rate switching" option wont be available for you; since you have only 60Hz as a default refresh rate without choice. But I do request you to wait for a reply from an official INTEL expert on the issue you're currently facing.
Ok, thanks a lot for the help.
Do I need to do something to get help from an official Intel expert?.
No need to do anything, just keep browsing this topic now and then,the intel expert will surely reply to this issue.
@ Maxim, Do you have the latest graphics drivers from the Samsung support site installed on your system or the latest graphics drivers from the Intel and Nvidia support sites?
Robert
Samsung has a program called SW Update which only has Intel drivers (Ver 10.18.10.3621) but I installed the drivers from intel cause of the problem but Samsung doesn't deliver Nvidia drivers so I downloaded them from Nvidia .
