23104 Discussions
Intel HD Graphics 630: анизотропная фильтрация, вертикальный синхроимпульс (Vsync)
ЕДроз2
Как отключить анизотропную фильтрацию и вертикальный синхроимпульс на Intel HD Graphics 630? Во вкладке 3D только это:
Hello Zenk,
Thank you for joining the Graphics community.
In this case you should be able to disable the Anisotropic Filtering and Vertical Sync within the application that you are using, the setting available in the Intel® HD Graphics control panel uses the default settings included within your apps. So, you should be able to disable them from there.
Amy C.
ЕДроз2
May I disable it via Intel Control panel?
/thread/117943 Zenk, via the Intel® HD Graphics control panel is not possible since the option is available within your apps.
Amy C.
