22828 Discussions
Intel HD Graphics 630 won't work no matter what I do
krishnakumar
Hi all,
I have a dell inspiron 15 7000 series - Inspiron 7577 model with intel hd graphics 630 integrated and additional graphics from nvidia (1060 with max q design)
If I change the drivers, either it errors out like how it is shown above or it results in a complete black screen making it unusable - I go into safe mode, delete the driver and then continue.
Windows has stopped this device because it has reported problems. (Code 43)
I have tried every tutorial available on the internet, including new os of windows with 20H2, 21H2 and 22H2. I don't know what can be done to fix this issue. This is causing a lot of trouble at my side, any help would be greatly appreciated.
Thanks in advance.
MUC
Honored Contributor I
Please try the drivers officially offered by Dell. With a laptop, only the device manufacturer can determine exactly which drivers will work without problems. The date of the drivers may seem old, but if in doubt, you are best off using the Original Equipment Manufacturer (OEM) drivers.
Dell Inspiron 15 Gaming 7577 (Windows 10, 64-bit):
krishnakumar
Hey @MUC , thanks for the reply
Unfortunately, it didnt work. i tried installing all the older versions available on the dell website too, but it throws an error saying the system doesn't match the requirements / results in the same error / installs properly but goes into complete black screen
I tried to install both using the installer that you gave and also manually, but both results in the same error.
Major drawback of this failing is I'm not able to adjust brightness, use night light and the screen is laggy and many softwares don't even work even though nvidia graphics is working fine
