23067 Discussions
Intel HD Graphics Control Panel tray icon always visible at startup
DMerl1
I have recently updated the driver of my intel graphics card to the latest versoin and since then the Intel HD Graphics control panel tray icon is always visible when I restart my laptop, despite having selected "Disable" tray icon from the preferences section in the control panel. I try to keep as little as possible in the system tray and this bug is very annoying.
I can manually hide the tray icon every time but it's not the ideal solution. Is this a know bug or does this just happen on my laptop?
SOWMYA_N_Intel
Issue: Intel HD Graphics control panel tray icon is always visible when I restart my laptop, despite having selected "Disable" tray icon from the preferences section
- This issue is fixed. Please use any latest drivers and the issue must not be seen.
Issue 2 : context menu isn't only applied in desktop, but also inside windows explorer!!! When I right-click anywhere inside a folder I can see Intel Graphics options!!!
Let us know if you still have any concerns
Kevin_M_Intel
Hi Drioz,
I am sorry you are having problems with the Graphics & Control Panel Try Icon but let me assist you.
I have tried to reproduce the problem but I was not able to replicate it meaning that it is not a bug with the driver so there are some instructions I want you to try:
  1. Open Graphics Control Panel> Preferences.
  2. Select Disable System Try Icon
  3. Click on Save.
  4. Save Profile.
  5. Restart the computer.
Hope it helps.
SMeen1
Same problem here!
I've tried everything, uninstalled, installed again, did what kevin said, still the same.
This very, very annoying!
Please, give us a solution.
I always used to click on Graphic options -> Tray icon -> Disable and it always work.
Now after the update it's not working! Disable is chosen, but the tray always appears.
I'm using Windows 8.1 64-bit on a multiple user machine.
Problem on both users desktops.
PLEASE HELP!
SMeen1
Another strange issue in this latest driver 3496 is that context menu isn't only applied in desktop, but also inside windows explorer!!!
I've never seen this in the other driver, nor the first tray icon issue!
I want to revert back to the old driver, but YouTube is horrible with the old driver...
PLEASE HELP!!!
DMerl1
I can confirm that what Kevin suggested did not work for me either. I'm also running Windows 8.1 64-bit on an i3-3217U and have the latest graphics drivers installed (10.18.10.3496). Looks like a bug, I hope it'll be fixed with the next version.
SMeen1
Hello again..
This is really getting me mad!
I was able to replicate same issue on my PC at work.
It has Windows 8.1 64-bit, single user. It's 3rd gen i-7, while PC at home is 4th gen i-7.
What I did is just download the driver from the link (64-bit: Driver Download http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 here) and install it.
It asked for a reboot, I did. After rebooting the tray icon is visible while the option Disable is chosen in context menu!!
I reboot again, still the same..
Please help
ROBERT_U_Intel
@ Shinawatraa, could you please post a screen shot of your desktop with the tray icon?
SMeen1
Here you go..
Screenshot # 1: http://oi58.tinypic.com/1128v9t.jpg http://oi58.tinypic.com/1128v9t.jpg
Desktop with tray icon.
Screenshot # 2: http://oi62.tinypic.com/2e2dtsm.jpg http://oi62.tinypic.com/2e2dtsm.jpg
Tray icon right-clicked.
Screenshot # 3: http://oi60.tinypic.com/2rw9ilz.jpg http://oi60.tinypic.com/2rw9ilz.jpg
Desktop context menu showing Disable tray icon option chosen.
Screenshot # 4: http://oi57.tinypic.com/2w2r81v.jpg http://oi57.tinypic.com/2w2r81v.jpg
If I go to control panel and click on Options and Support tray icon automatically disappears.
Screenshot # 5: http://oi57.tinypic.com/10r90cg.jpg http://oi57.tinypic.com/10r90cg.jpg
Right click on Local Disk showing graphics options in context menu.
Screenshot # 6: http://oi62.tinypic.com/p2jhg.jpg http://oi62.tinypic.com/p2jhg.jpg
Right click inside any local drive shows graphics options in context menu.
ROBERT_U_Intel
Thanks for the pictures, that helps a lot. We are investigating the issue.
ROBERT_U_Intel
@ Shinawatraa, The Tray Icon persistence issue will be resolved in the next driver release, however I do not have an ETA of the release date yet.
The Windows Explorer context menu issue is under investigation.
Robert
SMeen1
Will be waiting..
Thanks for your efforts guys, really appreciated.
amill21
I have met the same issue making me so annoying.
Even more serious is that in every time of boot there is always a error window showing on the desktop belong with "Intel HD Graphics Control Panel Tray" is "Enabled".
Once I disabled the setting, next time I boot into desktop it would not appear this error and tray icon, but the option of "show tray icon" would be ticked again.
I had tried to fox my windows and to disable all of other setup apps but it did not solve this problem.
Kevin_M_Intel
Thanks for the information. Check Answer 9.
PVita1
Hi - can we please have an update on this fix? Windows 8.1 64 bit on Lenovo X1 Carbon v.2 - Intel graphics icon persists, despite disabling in adapter settings. Returns after each cold start.
Paul
Kevin_M_Intel
pvdublo7,
As mentioned on response # 9, this issue will be resolved in a future driver but there is not ETA of the release date yet.
JRich17
I have also been experiencing this issue, does this mean nothing can be done until an update is released?
DLEPI1
Hello all,
I had a similar issue on my HP EliteBook 9470m (Windows 8.1 Enterprise) and I admit it was very annoying. I recently downloaded the latest version of the driver for my Graphic card: Intel Iris and Graphic driver for Windows 7 / 8 / 8.1 version 15.33.22.64.3621 released on 21th May 2014.
Now it works like a charm.
I hope this will help you
Kevin_M_Intel
It is good to know it is working now.
Kevin M
SMeen1
Tray Icon persistence issue has been resolved in latest driver 3621.
But the Windows Explorer context menu issue still unresolved!!!
Any idea?
SOWMYA_N_Intel
