22929 Diskussionen
Intel HD Graphics Driver 2000/3000 for Windows 10?
AViei2
Einsteiger
143.235Aufrufe
Hello, is there any estimate of when will release the driver for Intel processors 2nd Generation for Windows 10? Because this list: http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems there is already a driver for other generations of less 2nd. =/
Sorry my bad English. 😞
1 Lösung
Allan_J_Intel1
Mitarbeiter
133.406Aufrufe
The Intel® HD Graphics 2000/3000 is part of the 2nd generation graphics, please bear in mind the support for Windows 10 begins from 3rd generation graphics hardware.
The Intel® HD Graphics 2000/3000 does not have support for Windows 10.
Allan.
Lösung in ursprünglichem Beitrag anzeigen
19 Antworten
Allan_J_Intel1
Mitarbeiter
133.407Aufrufe
Allan.
AViei2
Einsteiger
133.405Aufrufe
But because the native driver for Windows 10 for 2nd will not be released? I can even use the Windows 8.1 but it has many bugs and memory consumption by the "System" process driver gets too high, coming close to 2 gb..
Kevin_M_Intel
Mitarbeiter
133.405Aufrufe
At this point there are no plans on releasing Windows 10 drivers for the second generation Intel Graphics Controller. You can try the latest driver from our side at this link:
https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit
Kevin M
Mitarbeiter
133.405Aufrufe
Hello Kevin,
Would you please advice of the fixes or additional support features of the windows 10 driver for intel hd 3000 v9.17.10.4459 you recently supplied Microsoft windows update catalog site? I would be grateful if intel reports additional information for their new driver. Is it just stability driver fixes??? or are there any other improvements, SUCH AS OPENGL V 3.3 or OPENCL 1.2 GPU support?? . I though you were not planning in supporting windows 10 x64. This came as a surprise to me.
Panayiotis
MCint2
Einsteiger
133.405Aufrufe
This is what I got from Intel Tech Support
Hello Marcos,
Thank you for visiting the Intel ARK web site. From what I've heard from Intel Support, Intel does not have plans to develop Windows 10 graphics drivers for the 2nd Generation Intel Core Processor family. Please visit your laptop manufacturer's web site for the latest drivers and updates specific to that laptop system.
If you wish to connect with Intel Support, that group can be reached through the Support web site:
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Lori Yung
ARK Support
ark.intel.com
So Intel doesn't care in updating a driver for an OS that is based on Windows 8. That way it forces the user to buy a newer Laptop (being that you cant just change the CPU on Lenovo W520).
A $1,300 laptop out dated in a few years.
Allan_J_Intel1
Mitarbeiter
133.405Aufrufe
This is the list of supported operating systems for your graphics controller: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Graphics Drivers
Allan.
Mitarbeiter
133.405Aufrufe
Do you have any information on my previous question regarding new intel hd 3000 driver posted on Microsoft update catalog 9.17.10.4459 x64 driver?? Thanks
GomerSaysHey
Einsteiger
120.102Aufrufe
I have downloaded and used the drivers from Intel and Dell and Microsoft (all the same)... but several things I found, 1.  you can use an external monitor, if possible, in a pinch & 2.  IF you install the DotNet 3.5 and restart the machine, it works most of the time.
AlHill
Superuser
120.100Aufrufe
This is a FIVE year old thread.  You should have started a new thread.
To save you time, there is no Intel graphics driver for Windows 10.
All you have is the Microsoft generic graphics driver, which lacks features and performance.
Short answer - Get a new or newer system that is supported by Windows 10.
YFirm
Einsteiger
133.404Aufrufe
I'm offended , maybe you offend me but quiet the download link I'm safe , I download it on intel HD Grapich driver, there are many who are not suitable for my pc but when I try it in win 8 it worked , then I tried installing win 10 and then use this driver turned out to work fully . and then I uploaded it on my blog , and I share the link here , for the benefit . http://adf.ly/1WzwAL Driver HD 2000/3000 Win 7, 8.1, 10 Pro x64. Work fine in my PC. you will try it.
preview :
MTens
Einsteiger
133.404Aufrufe
Thank's YoukaiFirmansyah It's work fine thank's
wOw in windows 10 work? oke I'm will upgrade to windows 10 now
YFirm
Einsteiger
133.404Aufrufe
thank you for beliving me, good luck
NPiri
Neuer Beitragender I
133.404Aufrufe
Microsoft has posted v9.17.10.4459 (5/19/2016) of the Intel HD Graphics drivers for the 2000, 3000 & 4000 series recently on the http://catalog.update.microsoft.com/v7/site/Search.aspx?q=9.17.10.4459 Microsoft Update Catalog site (for Windows 10 x64 only; need IE to view the MS Update Catalog site).
winbetaxp
Einsteiger
109.633Aufrufe
Core isolation memory integrity turns off because the latest windows 10 driver update  v9.17.10.4459 (5/19/2016) has issues with oem6.inf and igdkmd64.sys   Windows 10 Pro  v21H1  build date 19043.1266   can't use the security feature
AlHill
Superuser
109.343Aufrufe
This thread is more than 5 years old.
Start a new thread.
[Windows 11 is the new Vista]
Maiti
Einsteiger
91.099Aufrufe
Hola buen dia... estimado señor tengo el sigiente problema... lleve a actualizar a windows 10 y ahora no puedo escuchar nada cuando conecto mi compu al tele por cable HDMI solo pudo vere... antes podia ver y escuchar po HDMI mi computadora portatil es una ken brom con procesador intel i5 con placa intel y intel graphicg 3000 y 4GB ram.. espero puedan solucionarme ese incombeniente ya q nadie pudo solucionarlo y e gastado mucho tiempo y dinero y no funciona.. creo q me falta un drivers... muchas gracias espero su pronta respuesta
AlHill
Superuser
91.095Aufrufe
@Maiti Stay with your original thread.   One thread is enough.
Wertia
Anfänger
98.122Aufrufe
Nah can't speak about Windows 10 because people signed a contract saying they can't modify or fix it for free but Ubuntu has a fix for it.
https://github.com/intel/intel-graphics-compiler
Maiti
Einsteiger
91.000Aufrufe
Hola buen dia... estimado señor tengo el sigiente problema... lleve a actualizar a windows 10 y ahora no puedo escuchar nada cuando conecto mi compu al tele por cable HDMI solo pudo vere... antes podia ver y escuchar po HDMI mi computadora portatil es una ken brom con procesador intel i5 con placa intel y intel graphicg 3000 y 4GB ram.. espero puedan solucionarme ese incombeniente ya q nadie pudo solucionarlo y e gastado mucho tiempo y dinero y no funciona.. creo q me falta un drivers... muchas gracias espero su pronta respuesta........
Antworten
