22857 Discussions
Intel HD Graphics driver version 154028.4501 is not working with Windows 10 Anniversary Update???
SSmar2
It is successfully installed but not working. the driver is available in control panel, win10 settings, system32 folder, but not in right click menu and tray area. it is not opening from any where. after installing the driver it shows 5 screens in the display settings... please solve this problem. thanks in advance.
Hello SmartGamer278:
In order to fix this problem we can try the following, uninstalled the driver that is currently on the PC:
Please get into device manager, then look for "display adapters" select it and then right click on "Intel HD graphics" and select uninstall.
Then we can try to install the driver manually, here you have the instructions:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Here is the 45010 driver just in case:
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
If the problem remains after that, then we just need to verify a few details:
What is the model of the board?
What is the model of the processor?
If this is a laptop, what is the model of it?
Alberto
SSmar2
i uninstalled the driver, after that i installed it from device manager. it got the 20.19.15.4501 version. but not the 154028.4501.
Motherboard is Quanta JWU.
Processor is Intel Core i3 4010u.
Laptop model is Haier 7G-5H.
Windows 10 Pro 1607 (10.0.14393.222).
Stefan3D
Only the four-digit number is relevant.
Check out:
VVedr
Hello:
Thank you very much to all the peers viewing this thread.
If the problem persists after you tried the steps on this thread, then please submit your inquiry on a new thread, the reason for that is that every scenario is different, even if the same product is being used, so for us to provide assistance on your specific product, please submit a new thread.
Let me apologize for any inconvenience.
To SmartGamer278:
Thank you very much for that information.
Perfect, the driver even if the numbers at the beginning are different, it is the same driver 4501.
So, if the driver got installed, then the graphics on the PC is now 4501.
Alberto
Hello:
Thank you very much to Ronald_Intel for the information provided on the previous post.
To SmartGamer278:
I hope the information posted previously was useful for you, at this point we need to wait for the new driver released, so please keep checking the thread provided by Ronald_Intel , since once the new driver is available you will find all the details in there.
Thank you for your patience.
Alberto
Hello:
Thank you very much to Ronald_Intel for the information posted above.
To SmartGamer278:
Please try to install the driver provided previously and let us know the results.
Alberto
I just wanted to check if you were able to install the driver provided previously, and if the problem still persists or if it was resolved?
Alberto
RonaldM_Intel
Hello SmartGamer278,
I would like to let you know that the following issues show as fixed in our latest 15.40 internal build:
1. Multiple non-existing monitors show up when Hyper-V is enabled.
2. Graphics Control Panel is not available when Hyper-V is enabled.
We appreciate your patience while we post this new driver on DownloadCenter.intel.com.
I'll update the following thread once the driver is officially released:
https://communities.intel.com/thread/110642 https://communities.intel.com/thread/110642
Kindest Regards,
RonaldM_Intel
Hello Everyone,
We just posted a new 15.40 test driver that should fix this issue.
Details can be found here:
Please give this one a shot and let us know your feedback.
By the way, we apologize for the delay in getting this one out.
Kindest Regards,
