22378 Discussions
Intel HD730 and 750 gives artifacts with Netflix 4K + HDR
Roland_87
Situation
Okay, I have two Intel different Intel 11th gen systems. I have installed Windows 10, the Netflix app, the latest drivers (30.0.100.9955) and the HVEC codec from Microsoft (Link to Microsoft store ).
When playing 4K HDR content like:
  • 6 underground
  • Squid game
Then all kind of black and white artifacts pop-up on both systems.
Tested
  • Used two different Intel 11th gen systems
  • Used direct HDMI to LG TV or with a receiver in between
  • Tried to lower ram speed (2933MHz to 2133MHz) to test for memory issues
  • Tried different HDMI cables
  • Happens ONLY using Netflix
  • Tried to use Netflix in Microsoft Edge browser, which results in the same incident
  • Updated firmware of LG TV to latest state
  • Updated Bios of both motherboards
  • HDR is switched ON and OFF
  • Problem is highly related to HVEC decoding because the problem disappears when switching back to full HD
  • Issue seems to be related to other topic on forum
  • Tested this issue with other Intel system from friend (also 11th gen) and same problem appears
Suspect
I suspect that there is a decoding issue with the drivers or somehow an incompatibility with Netflix 4K. If you need more information, I will provide further details.
Labels (2)
Roland_87
Can anyone help me out with this issue?
Roland_87
Forgot to add Graphics Bug Report. 🙂
