22989 Discussions
Intel IGD HD 500 qemu passthough to Win10 VM driver problem
DDere1
I can passthrough the HD 500 fine and it works without the Intel HD driver. However upon installing the Intel driver, the vm will experience problem with the device (yellow exclamation mark on the device list window). There would be no graphics output and I need to use remote desktop to log in and uninstall the device for it to work again, though at this point there is no intel driver associated with the device.
I tried the same configuration on HD 530 (G4500 CPU) and it works perfectly. Something is broken with the new kaby lake drivers?
I am sorry to hear about this issue with the Intel® graphics drivers.
Please confirm if you were able to install driver version 4552.
https://downloadcenter.intel.com/download/26464/Intel-Graphics-Beta-Driver-15-45-?product=96553 https://downloadcenter.intel.com/download/26464/Intel-Graphics-Beta-Driver-15-45-?product=96553
Allan.
DDere1
nope, can't install. tried the previous version and the manufacturer's version too to no avail. my board is j3455-itx by Asrock.
DDere1
It seems that your board model only allows the installation of customized drivers by ASRock.
Please test installing graphics drivers manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10
Additionally, try ASRock drivers: http://asrock.pc.cdn.bitgravity.com/Drivers/Intel/VGA/VGA(v15.45.4.64.4494).zip 4494
Allan.
DDere1
I tested both the Intel (manual, zip and the exe) and the Asrock driver (manual and exe) still does not work.
DDere1
the install log contains this:
Matched HardwareID = PCI\VEN_8086&DEV_5A85
Installed Driver = {4d36e968-e325-11ce-bfc1-08002be10318}\0001
Found current package 21.20.16.4552
Found current package INF: C:\Windows\inf\oem9.inf
Found current package Installed INF: oem9.inf
Removed C:\Users\Derek\Desktop\win64_154512.4552\DisplayAudio\10.22\IntcDAud.inf
Removed C:\Users\Derek\Desktop\win64_154512.4552\DisplayAudio\6.16\IntcDAud.inf
Checking 4 part DID's
if nInfIdCount == 2
opening INF file C:\Windows\inf\oem9.inf
4ID check OK
! Hardware ID not found [5A85].
Checking for downgrading
[Checking INF versions]
C:\Users\Derek\Desktop\win64_154512.4552\Graphics\igdlh64.inf
Intel(R) HD Graphics
Installed version: 21.20.16.4552
Version in package: 21.20.16.4552
Installed INF info: Name=Graphics, Provider=Intel Corporation, Section=iBXTD_w10_DS
Please run and attach the following report: http://www.intel.com/content/www/us/en/support/siu.html Intel® System Identification Utility
Allan.
DDere1
Intel System Identification Utility Reference Number: 0373 9842
Date Created: Tuesday, December 20, 2016 7:24:56 AM
ADVANCED SYSTEM INFORMATIONComputer Manufacturer Computer Model Operating System (O/S) Microsoft Windows 10 (build 14393), 64-bitOperating System Build (O/S)14393Operating System (version) 10.0.14393O/S Language0804System RAM 4.0 GB.NET Framework Version4.6.2CD or DVD Device QEMU QEMU DVD-ROM ATA DeviceSystem Hard Drive OverviewSystem Total Storage Size:59.5 GBCD or DVD Device QEMU QEMU DVD-ROM ATA DevicePhysical Drive0MakerRedModelHatVirtIOBus TypeSCSILocal Disk C:\59.5 GBUsed space:19.5 GBFree Space:40.0 GBMemory DetailTotal Physical Memory4.0 GBAvailable Physical Memory2.6 GBTotal Virtual Memory2.0 GBInternet Browser [101]Internet ExplorerInternet Browser Version [101]11.576.14393.0 GRAPHICS INFORMATIONGraphics Product [1]Intel(R) HD GraphicsGraphics Driver Version 21.20.16.45523D AccelerationNoHardware Transform & Lighting Support NoVideo Memory0.0 BVertex Shader Support 0.0Pixel Shader Support 0.0Microsoft DirectX* Version 11.0Current Graphics Resolution1920x1080Current Color Depth32 Bits Per Pixel MOTHERBOARD INFORMATION Manufacturer not detectedModel AA Numbernot detectedBIOS VendorSeaBIOSBIOS VersionSeaBIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.orgBIOS Release Date04/01/14System Memory4.0 GBSound CardHigh Definition Audio 设备 PROCESSOR INFORMATIONManufacturerIntelModel http://www.intel.com/p/en_US/support/ Intel(R) Celeron(R) CPU J3455 @ 1.50GHzIntel Processor analysis toolshttp://www.intel.com/support/processors/sb/CS-015477.htm Intel Processor analysis tools CPU Speed1.5 GHzLink to Processor Specificationhttp://ark.intel.com/ Link to Processor SpecificationCPU RevisionCPU Type00CPU Family06CPU Model5CCPU Stepping9 WIRED NETWORKING INFORMATIONWired Networking ProductIntel(R)82567LM-4basedNetworkController(OEM)Driver Version100.73.104.12600Hardware IDsPCI\VEN_1AF4&DEV_1000&SUBSYS_00011AF4&REV_00 </...
Thank you for the report. I appreciate it.
I have been testing driver version 4552 on several Intel® HD graphics models, if this was a driver failure, it will happen on every computer I have tried so far.
It seems a registry problem with the operating system. You could try running system restore and try restoring Windows registry.
https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options
Allan
DDere1
All those installations were done on fresh Windows 10 installs. It's specific for Intel HD 500 only. I have no problem with HD 520 and 530 on G4000s skylakes
TSait4
I think I have same problem, and don't have any clue to solve it.
Can I contribute to solve this problem by offering other information?
I passthroughed the IGD to Windows 10 home VM. But the GPU driver does not work, issuing error "Core 43".
My board is ASUS J3455M-E.
There is a new driver version that was just released, try version https://downloadcenter.intel.com/download/26563/Graphics-Intel-Graphics-Driver-for-Windows-15-45- 4590
Hope this information is helpful.
Please do let me know if you need further assistance with your Intel product, I will be glad to assist you.
Allan.
TSait4
Thanks for your quick reply.
I have tried the driver you mentioned above already, but the result was same.
To clarify what causes this problem, could you kindly give me the directory where the install log is generated?
The install log is one which CateFul gave us previously(No.6, 2016/12/19 12:01).
And more, do you know why the line below was ouput in the CateFul's log?
The install log is usually located at C:\Intel\Logs
I do not have information about the hardware ID 5A85
You could also check for customized graphics drivers from your motherboard maker or computer manufacturer.
Allan.
