System Used: Custom
CPU SKU: i5-5675C
GPU SKU: Intel® Iris™ Pro Graphics 6200
Processor Line: ?
System BIOS Version: Z97-PRO GAMER BIOS 2203
CMOS settings: Default
Graphics Driver Version: 20.19.15.4444
GOP/VBIOS Version: 1030.0
Operating System: Windows 10 Pro
OS Version: 10.0.10586
API: DirectX 9
Occurs on non-Intel GPUs?: No. AMD & NVIDIA cards were fine (HD 7950 and GTX 750 Ti tested)
Steps to Reproduce:
1. Clean install Windows 10
2. Open Counter Strike Global Offensive
3. Select Play offline with bots on cs_office
4. Play for some time then quit
5. Restart the game, play on the same map
(Maybe change graphics settings to low)
Expected Results:
The game should run without artifacts.
Actual Results:
The first time you play it will be fine. After that it's broken forever. It' like an overly aggressive HDR applied to the game. Everything gets darken to the point where you can barely see things in the dark.
Additional Information:
Please check the screenshots: http://imgur.com/a/LJnlq
(I couldn't upload the images here, the uploader doesn't worked for me)
Hi Viktor,
You need to go to the Intel customer support community: https://communities.intel.com/thread/77761
You can report your issue and get support there. This forum is devoted to game developers working on Intel Graphics.
-Michael
