23089 Discussions
Intel Iris XE not supporting 5120x1440 resolution
Talderon
I have looked at many older posts to get information, but with this being such a new laptop, I have not been able to find a solution that works.
Here is what I am running:
Laptop: E15 Gen 2 (Type 20TD, 20TE) Laptop (ThinkPad) - Type 20TD
Operating System: Windows 11 Pro (version 21H2 (OS Build 22000.652))
Graphics Card: Intel Iris Xe Graphics
Driver Version: 30.0.100.9955
Monitor: LC49G97TSSNXDC - Samsung Odyssey G9 49" Ultrawide Monitor (up to 240hz)
I have the latest drivers and BIOS available, so everything is updated. Right now, the max resolution is 3840x1080 and it looks like hell.
I'll be honest, this is the first time I have used and Intel graphics card (as in not getting something with an nVidia card) and I am less than impressed at this point. WHY is it so hard for a company to just add support to a resolution that it pretty standard.
Sorry, needed to vent, but this is just pain frustrating.
Thanks all!
Talderon
Well hell, after a reboot, 5120x1440 showed up! 🙂
Talderon
I found an updated driver: 30.0.101.1660 and no change. 😞
Talderon
Steven_Intel
Hello Talderon,
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior.
Since the thread is now solved, we will proceed to close it.
Please keep in mind that this thread will no longer be monitored by Intel.
Steven G.
Perdun
I have INTEL Nuc with i7-1360P and Intel Iris Xe Graphics
Can I have more than 60Hz with 5120x1440, my monitor Samsung SRG9 supports 120 Hz
MUC
Honored Contributor I
Samsung CRG9
  • 5120 x 1440 @ 120 Hz 10-bit HDR
  • 32:9
  • VESA Adaptive Sync
  • 1 x HDMI 2.0
  • 2 x DisplayPort 1.4
Intel NUC 13
DisplayPort 1.4a HBR3 (with DSC) tunneling on USB-C/Thunderbolt ports on the back:
If you connect your monitor with one of these cables, you shouldn't have any problems:
