20622 Discussions
Intel® Iris™ and HD Graphics Driver update posted for Haswell and Broadwell
ROBERT_U_Intel
This update addresses several previously found issues. Please see the Release Notes excerpt below for details. As always, feedback is appreciated.
The 15.36.7.3960 has been posted to Intel Download Center at the following direct links to the drivers:
32-bit: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24349 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24349
64-bit: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24348 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24348
This driver supports the following:
4th Generation Intel® Core™Processors with Intel HD graphics,
Intel Iris™graphics and Intel Iris Pro graphics.
Select Pentium®/ Celeron® Processors with Intel® HD graphics, and
Intel® Core™ M with Intel® HD Graphics 5300
Here is a brief list of the new features in this release:
  • Improved video playback experience with enhanced Frame Rate Conversion based on global motion vectors
  • Reduced total file size of the driver on system storage
  • Graphics control panel setting to force Anisotropic Filtering now works correctly on all DirectX9, DirectX10 and DirectX11 based applications
  • Added OpenGL support for:Graphics control panel setting for CMAA* (Conservative Morphological Anti-Aliasing) now works on OpenGL applications
    • ARB_texture_mirror_clamp
    • GL_EXT_TEXTURE_ARRAY
    • Reduced recompilation of shaders in multi-context scenarios
  • Added support for OpenCL extension cl_intel_simultaneous_sharing to allow sharing of memory buffers between OpenCL, OpenGL, and DirectX. This feature is used by Adobe* applications such Photoshop CC*
  • This driver brings performance on Dirt 3* back to parity with the last 15.33 driver
  • Up to 50% improvement with OpenCL benchmarking application *CompuBench and up to 10% improvement with Sandra 2014*
  • This driver is compatible with the Intel® Integrated Native Developer Experience (INDE) 2015 - Media RAW Accelerator and INDE 2015 - Media SDK for Windows
Key issues resolve with this release:
</span...
JLloy5
Hello @Robert_U and Intel Community,
I have updated my driver to 10.18.10.3960 so that I can play Titanfall without the strange stretch graphics. The graphics are now fixed and everything plays incredibly smooth, but now I get a titanfall.exe has stopped working and a popup. "Display driver has stopped responding and has recovered. Display driver intel HD graphics for windows8(r) has stopped responding and has successfully recovered." This happens every time about 1 to 5 minutes paying. I have had a hard time finding a solution online.
Would anyone happen to have any ideas to what the problem may be? Am I just waiting for an update? Could it be a page file issue?
i7-4500u @ 1.80GHz (4 CPUs) 2.4GHz
Memory: 8192MB RAM
Page File: 2807MB used, 9845MB available
Thanks a million.
-James
ADell4
I have upgraded to the latest Intel driver 10.18.10.3960 on a HP EliteDesk 800 Mini with dual DisplayPort HP connected monitors. The issue that happens is when the PC comes out sleep the secondary monitor does not resume at original resolution as it went to sleep with.
If l disconnect the DisplayPort cable and re-connect it comes back at the correct resolution.
Can you please advise?
MDonn2
I have a Yoga Pro 3 which routinely crashes a few minutes into Neverwinter game with the following error:
Fatal Error: Direct3D driver returned error code
(DXGI_ERROR_DEVICE_REMOVED) while checking sync query
Technical Details: sync query 0 0x15ddf780 GetData == 0x887a005 0 NF 0
D3D11 Device removed due to E_OUTOFMEMORY 0x8007000e
A printout of DXDIAG is appended below.
Things I have tried:
- made sure I had the latest video drivers from Intel for the 5300
- research on the above code suggests that the last driver that would not crash on a particular game was 9.17.10.2932 in December 2012 LINK: /thread/46821 https://communities.intel.com/thread/46821 I was not able to install that driver but I was able to roll back to a generic driver from 2006 that seemed to extend time until crash from 5 min to at least an hour. At some point system put latest Intel driver on again so I dont know if old driver ever crashed.
- installed latest video drivers from Lenovo which are a few months older than the intel drivers even though they were posted later than most recent intel drivers
- worked through several solutions with tech support from Cryptic/Neverwinter which led us both to the conclusion that this is a video driver issue.
Help will be appreciated.
System Information
Time of this report: 12/12/2014, 09:08:16
Machine name: **REDACTED**
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 80HE
BIOS: A6CN38WW
Processor: Intel(R) Processor 5Y70 CPU @ 1.10GHz (4 CPUs), ~1.3GHz
Memory: 8192MB RAM
Available OS Memory: 8108MB RAM
Page File: 5671MB used, 5507MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 240 DPI (250 percent)
DWM DPI Scaling: UnKnown
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 5300
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_161E&SUBSYS_390617AA&REV_08
Display Memory: 3839 MB
Dedicated Memory: 0 MB
Shared Memory: 3839 MB
Current Mode: 3200 x 1800 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SDC434A
Native Mode: 3200 x 1800(p) (60.000Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3960 (English)
Driver Version: 10.18.10.3960
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: Triangle
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 10/3/2014 17:36:50, 24185400 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-555E-11CF-627B-0C19B5C2C735}
Vendor ID: 0x8086
Device ID: 0x161E
SubSys ID: 0x390617AA
Revision ID: 0x0008
**OMITTED for BREVITY***
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
JKERL1
Hello, I'm a new user...
I have an XPS13 next gen and I have an issue with the driver of intel !
I have a latency with my keybord (usb or include keyboard)
I do a fresh install of W8.1 .. No lag ... I install the intel driver 15.36.7.3960 or older, the lag start !
I have a i7-4510U and Intel HD Graphics 4400.
ROBERT_U_Intel
@ jpkerloch,
Your Dell system is shipped with a graphics driver that has been very customized by Dell to work correctly on your system. I would not recommend using the generic Intel HD Graphics driver unless you absolutely have to as you will loose all of the Dell customizations.
You can get the latest Dell drivers for your system here: http://www.dell.com/support/home/us/en/04/product-support/product/xps-13-9333/drivers Product Support | Dell US
Robert
kinoa
apperantly intel just cares about the 4th generation because they fixed anistropic filtering on the 4th generation but they never tried to fix the intel 4000 anisotropic filtering
