20626 Discussions
Intel Q35 at 1360x768
My company wants to buy an Information System.
This Information System works works with NEC MultiSync LCD4020 and NEC Multisync LCD4620 monitors at 1360x768 or 1366x768.
We are planning to use two HP desktop that have Intel Q35/GMA3100 running Vista Business x32bits with the above mentioned monitors at precisely 1360/1366x768 resolution.
My question is if Intel Q35 can give this resolution of 1360x768
Thank you in advance
Hi there,
Maybe it is worth for you to check this:
Website: http://www.intel.com/design/chipsets/datashts/316966.htm http://www.intel.com/design/chipsets/datashts/316966.htm
Page: 362/437
It gives the maximum resolution that the chipset can support. Now regarding a particular resolution, it depends on the driver itself. Make sure to install the monitor drivers as well, as it makes a big difference.
Hope this helps a bit.
