22139 Discussions
Intel(R) HD Graphics 8.15.10.2900
nycpandas
Where can i find the download for this driver?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Waiting for Windows 12]
nycpandas
File attached.
(Virus scan in progress ...)
AlHill
Sorry, there is no Intel driver for your graphics on Windows 10.
Your system is simply too old.   Time for a new or newer system that supports an 8th gen or later processor.
NLoia
Hi!
OK, I understand that there's no newer version of the Intel HD Graphics "8.15.10.2900" but, one clarification, please:
Since it is working fine, there's no need to exchange it. Right?
I have a HP G42-230BR (model:XD019LA) running W10 with this same graphic card and it's all OK.
Including I am writing in it now.....
Best regards.!
dimasik81
Prompt! Where can I find a newer driver than this?
The second monitor via Display Port does not work for me with this driver...
nycpandas
Worked for HP PC - not sure if it'll work on your system, but trying a previous version worked.  It'll prompt you a more updated version is on your system, and you'll click Yes to override and use the older version.
SP50249.exe
Armaan
Hi bro I need Help me My Version Also this same so I want how to download and solve thank you !
