22827 Diskussionen
Intel(R) HD Graphics in Toshiba L675-S7018
TBert1
Einsteiger
4.508Aufrufe
Is the any way to edit the ini file of a built in Intel HD Graphics to make it OpenGl 4 compatible ? Here is all the infor I have on the graphics:
Adapter Type Intel(R) HD Graphics (Core i3), Intel Corporation compatible
DriverVersion 8.15.10.2189
INF File oem27.inf (iILKM0E section)
Installed Drivers igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Report Date: 8/22/2017Report Time[hr:mm:ss]: 4:30:52Driver Version: 8.15.10.2189Operating System: Windows 7 Service Pack 1(6.1.7601)Default Language: English (United States)DirectX* Version: 10.0Physical Memory: 7986 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 59 MBProcessor: Intel64 Family 6 Model 37 Stepping 2Processor Speed: 2261 MHzVendor ID: 8086Device ID: 0046Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD GraphicsVideo BIOS: 1994.0Current Graphics Mode: 1600 by 900
1 Lösung
Stefan3D
Geehrter Beitragender II
2.481Aufrufe
According to https://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html Supported APIs and Features for Intel® Graphics Drivers your 1st Gen Arrandale GPU is limited to OpenGL 2.1
It's technically impossible to increase it to OpenGL 4
Check all capabilities with following tools:
http://www.ozone3d.net/redirect.php?id=401 GPU Caps Viewer
https://www.saschawillems.de/?page_id=771 glCapsViewer
http://realtech-vr.com/admin/glview OpenGL Extensions Viewer | realtech VR
Lösung in ursprünglichem Beitrag anzeigen
5 Antworten
Stefan3D
2.482Aufrufe
Mitarbeiter
2.481Aufrufe
Hello tbonpc,
This is a driver most likely customized by your computer manufacturer and as Stefan3D already mentioned there is no way to modify it.
I'm sorry this is not the answer you were looking for but this is the reality with this driver.
Ivan U.
TBert1
Einsteiger
2.481Aufrufe
Worth trying, if not for being in a laptop I would just go but another video card. Thanks
Mitarbeiter
2.481Aufrufe
You are more than welcome!
Ivan U.
TBert1
Einsteiger
2.481Aufrufe
Ok thanks for the info. Always worth trying.
Antworten
