Annunci
23511 Discussioni
Intel(R) Trusted Execution Engine Interface - Problem
Partsgirl95
Nuovo utente
36.759Visualizzazioni
Hello, My issue is with PC Freezing and the only option to recover from the freeze is a hard boot. CTRL/ALT/DELETE, for task manager- no response. From what I can see, there was a Windows Update installed on 9/4/2020.
Acer Aspire AXC-603G-UW14
This device cannot start. (Code 10)
STATUS_DEVICE_POWER_FAILURE
DeviceInstanceId
PCI\VEN_8086&DEV_0F18&SUBSYS_085E1025&REV_0E\3&11583659&0&D0
DriverName
oem3.inf
ClassGuid
{4d36e97d-e325-11ce-bfc1-08002be10318}
ServiceName
TXEIx64
LowerFilters
UpperFilters
Problem
0xa
Status
0xc000009e
Device name      Diana
Processor            Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz   1.99 GHz
Installed RAM    4.00 GB (3.88 GB usable)
Device ID
Product ID
System type       64-bit operating system, x64-based processor
Pen and touch   No pen or touch input is available for this display
Edition  Windows 10 Home
Version                20H2
Installed on  ‎9/‎4/‎2020
OS build               19042.685
Experience         Windows Feature Experience Pack 120.2212.551.0
I’m trying to avoid a clean install of Windows. I saw another post that was having the same issue, just a different make/model. The solution was:
1 - Download the "Intel(R) Trusted Execution Engine Interface" driver located under "Others" in the link below:
 https://www.asus.com/us/Laptops/E403SA/HelpDesk_Download/ https://www.asus.com/us/Laptops/E403SA/HelpDesk_Download/
 *Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there.*
 2 - Disconnect the system from the internet.
 3 - Go to device manager and uninstall the driver that is currently installed.
 4 - Reboot the system and then reinstall the driver downloaded previously.
 5 - Reboot the system again and then check if the error persists.
The user reported back that this did the trick. Can you please confirm that I should take the same steps, and if so, can you please provide a link for it? The post for the resolution was two years prior, and my issue seemed to show up during a Windows Upgrade 9/4/2020.
I appreciate any input that can be provided.
1 Soluzione
n_scott_pearson
Super utente
36.743Visualizzazioni
What are you looking for? This is good guidance, so follow it.
Frankly, AFAIAC, you should reinstall Windows 10 at least once a year anyway.
Visualizza soluzione nel messaggio originale
6 Risposte
n_scott_pearson
Super utente
36.744Visualizzazioni
Partsgirl95
Nuovo utente
36.728Visualizzazioni
My main concern is that my computer is randomly freezing up and stays frozen until a hard boot is done. I did not know it was standard to reinstall windows 10 annually, but appreciate that information. When I noticed the issue with the freeze, my first thought was to check the device manager. Thats when I saw an issue with the Intel Trusted Execution Engine Interface. I have a Logitech Webcam that I use, and disconnected it two nights ago. No freeze since then. I will follow your recommendation and take it from there.
n_scott_pearson
Super utente
36.638Visualizzazioni
Oh, I wouldn't say that it is "standard" (well, other than for me). What I will say is that reinstallation will clean up and simplify the file system and the registry and the cumulative affects of incremental updates, speeding things up significantly. There are a spate of apps that claim that they can do this without requiring a reinstall, but I have literally *never* found this to be the case; they are all too coarse and, in many cases, destructive in their operation.
Just my opinion,
Partsgirl95
Nuovo utente
36.632Visualizzazioni
Thanks for breaking it down for me. NOW it makes more sense to me and will be taking your advice. The beginner feels much better, Thanks!
Stefan3D
Collaboratore onorario II
36.734Visualizzazioni
The driver for your particular computer is here:
https://www.acer.com/ac/en/US/content/support-product/5175;-;Aspire%20XC-603G
Partsgirl95
Nuovo utente
36.727Visualizzazioni
Thanks, I saw that. Appreciate the input.
Rispondere
