Hello all,
Like the subject title, onboard uhd 630 won't display above 100hz on my Gigabyte 34" 144hz ultrawide monitor. The native resolution for this monitor is 3440x1440p at 144hz. The highest refresh rate I am able to set it to is 120hz at 2560x1440p. I've tried both hdmi and display port cables (1.2 and 1.4) with no luck. I'm assuming the integrated graphics does not support 144hz at native resolution? I've tried creating a custom resolution via intel command center, changing resolution through display settings and through list all modes with the same results. I have attached a pic of the display settings for my monitor showing max refresh rate at 100hz. All drivers updated. Idk if I should return monitor since I can't take advantage of the advertised refresh rate. Thanks in advance!
My new pc build specs:
i9 10th gen 10850k
crucial ballistix16gb ram ddr4 3600mhz
msi mpg z490 gaming edge wifi
windows 10 pro 64-bit
gigabyte g34wqc 34" ultrawide monitor
no gpu card as I am still waiting to buy one
Hello johnnyt120
- Do you use straight connections? (No adapters/converters)
- Did you test different drivers?
- Which BIOS version are you using?
- What is the maximum resolution/refresh rate shown in the IGCC?
I will send you an e-mail to the e-mail address associated with your community profile requesting some reports that may contain sensitive information.
David G
Hello johnnyt120
David G.
Hello johnnyt120
David G.
