I have been trying to build an htpc. Whenever I update all drivers to latest version and try and enable HDR, the screen goes black and I cannot get video access back. This is off an HP prodesk 400 g4 dm with the HDMI module. The display device is a Vizio D70-F3. I found other references to this issue in the latest Windows 10 with the last intel 630 drivers. A workaround that works is to downgrade drivers to v23 and it works great. I would love to get everything working with the latest drivers. What broke since v23?
Thank you!
- « Previous
- 1
- 2
- Next »
Hello FSt-P
Thank you for confirming that you have completed the test wit the OEM drivers, try completing the driver update by Windows® as advised previously to see if the behavior still persist.
I would also start taking into consideration that this could be related to the OEM customization/design because as mentioned previously I have run the latest Intel® graphics driver (26.20.100.7584) with HDMI® connections and the HDR option does not have any issue, therefore, it would be important to contact HP support for further assistance, and if HP determines that the issue is related to an Intel component they should work directly with Intel.
Leonardo C.
A Contingent Worker at Intel
- « Previous
- 1
- 2
- Next »
