22946 Discusiones
Intel UHD-750 doesn't display 2k 75Hz on external monitor
dapxe
Principiante
58.193 Vistas
    My PC doesn't display 2k (2560x1440) with fresh rate 75Hz although my monitor support 75Hz on 2560x1440.It's only support 60Hz maximum in resolution 2560x1440.
   - I have updated the last driver ( version 30.0.100.9864)
   - I tried using HDMI 1.4 cable and HDMI 2.0 cable to connect
    - My motherboard is ASUS PRIME B560M-K and my processor is i5 -11500
    - My monitor is ViewSonic VX2780-2K-SHJD
Please help me to resolve this problem.
0 kudos
35 Respuestas
RonaldM_Intel
Moderador
21.067 Vistas
Hello @dapxe
The information provided on the link you selected is accurate i.e. in order to drive the 2560x1440@75Hz video mode the pixel clock requirement is +- 304.25Mhz. The Intel Xe Graphics can support much more than that through its native HDMI 2.0 capability, however because the input on your monitor is HDMI 1.4 it forces Intel Xe to operate in HDMI 1.4 mode, and here the pixel clock is limited to 297MHz.
I would suggest perhaps test by using an HDMI 2.0-to-DP 1.2 adapter/converter so you can use the DP 1.2 input of this monitor.
Ronald M.
dapxe
Principiante
21.049 Vistas
Hello RonaldM_Intel
Thank you for giving a concise and clear answer to my problem.
Reading your reply I understand that the UHD-750 is limited to 297MHz pixel clock when operating in HDMI 1.4 mode.
So when I connect my monitor to the UHD-750 via HDMI 1.4 it won't work at 2560x1440@75hz.
Here my problem has been clarified. You can close this topic.
Best regards.
Alx24
Nuevo Colaborador II
21.016 Vistas
Under the same apparently limitation fell and very close in traffic to 2560x1440 at 75 Hz resolution of 2560x1600 at 60 Hz, which first appeared in Intel Core 5th Generation, but then did not appear in HDMI 1.4 Graphics until 11 Generation
when connecting a 4K display.
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/mobile-5th-gen-core-family-datasheet-vol-1.pdf
Alx24.
Alx24
21.269 Vistas
In the table in attachment A1.jpg above, the last line with the maximum resolution for Core 11 Generation Graphics
specified:
5120 x 3200, 60 Hz, 1042.5 MHz, 31.28 Gb/s
Displays with this resolution also very often have increased refresh frequencies of up to 75 Hz and above.
LG 40WP95C UltraWide Monitor ( Model 2022 )
https://thunderboltlaptop.com/best-thunderbolt-4-monitors/
Resolution: WUHD (5120x2160), 72Hz
Also for it is indicated and 75Hz.
Lenovo ThinkVision P40w-20
https://psref.lenovo.com/syspool/Sys/PDF/datasheet/ThinkVision%20P40w-20_datasheet_EN.pdf
Resolution 5120 x 2160
Refresh rate 75Hz ( Thunderbolt™ and DisplayPort™ only )
DELL U4021QW
https://www.displayspecifications.com/en/model/81f222f6
5120 x 2160 pixels
Refresh rate: 24Hz - 86Hz
Alx24.
Alx24
21.265 Vistas
specified:
Displays with this resolution also very often have increased regeneration frequencies of up to 75 Hz and above.
DELL U4021QW
5120 x 2160 pixels
Alx24.
Alx24
21.247 Vistas
Noticeably decrease in the popularity of the audio-visual interface HDMI,
which played a huge recognized role in the preceding time, in mobile systems
and as a consequence of this connectors mini-HDMI, micro-HDMI. It's not in Microsoft Surface
and LENOVO Yoga. With HDMI there are sensitive limitations, but it is quite successful
and appreciated in 4K TV's, HDMI 2.1 is in modern 8K TV's.
In terms of the number of connectors in HDMI monitors, it exceeds or is not inferior to DP if the monitor
has both inputs, it is still supplied with a factory HDMI cable.
https://www.intel.com/content/www/us/en/products/details/processors/core/i5.html
"12th Generation Intel® Core™ i5 Processors"
https://www.intel.com/content/www/us/en/products/details/processors/core/i7.html
"12th Generation Intel® Core™ i7 Processors"
New graphics Intel® UHD Graphics 770, which is worth paying attention to:
https://www.intel.com/content/www/us/en/products/sku/134594/intel-core-i712700k-processor-25m-cache-up-to-5-00-ghz/specifications.html
"Intel® Core™ i7-12700K Processor"
Graphics Output eDP 1.4b, DP 1.4a, HDMI 2.1
Execution Units 32
Max Resolution (HDMI)‡ 4096 x 2160 @ 60Hz
Max Resolution (DP)‡ 7680 x 4320 @ 60Hz
Max Resolution (eDP - Integrated Flat Panel)‡ 5120 x 3200 @ 120Hz
https://www.intel.com/content/www/us/en/products/docs/processors/core/core-technical-resources.html
https://cdrdv2.intel.com/v1/dl/getContent/655258
8.0 Graphics
9.0 Display
9.1 Display Technologies Support
HDMI* 2.1 High-Definition Multimedia Interface Specification Version 2.1
Notes: Processor support native HDMI* 2.1 TMDS compatible ports
Processor support non-native HDMI* 2.1 port by using DP* to HDMI* protocol converter
HDMI 2.1 is actual also in high frequency monitor area:
https://thunderboltlaptop.com/hdmi-2-1-monitors/
"9 Best HDMI 2.1 Monitors – Buying Guide (2021)"
For 5Kx2K display's HDMI 30 Hz is suitable.
Alx24.
AndrewG_Intel
Empleados
21.220 Vistas
Hello @Alx24
Thank you for posting on the Intel® communities and for all the time you took to share information, suggestions, links, and comments. We appreciate it when community peers are interested in trying to help other users.
Andrew G.
AndrewG_Intel
Empleados
21.220 Vistas
Hello @dapxe
In regards to your inquiries, we would like to inform you that we go over official specifications and through HDMI 1.4 we guarantee 4K@30hz; however, 2560x1440 @ 75Hz already pushes HDMI 1.4 bandwidth.
The Intel® Graphics Report properly detected the Supported Video Mode of 2560x1440 @ 75Hz meaning it is identifying the resolution correctly.
Also, our latest generic driver has been confirmed to be able to push 4K@60Hz over HDMI 1.4 and 5K@60Hz over DisplayPort (DP) 1.4 thus it is not a driver issue.
Do you see if the desired resolution is available in Windows® Settings > Display, and Under Advanced Display Settings?
As we previously pointed out, there are other factors that we don't control that may impact the availability to achieve the resolution + refresh rate and at this point, it seems it would most likely be needed to use DP 1.2 or HDMI 2.0 to successfully drive this video mode.
Andrew G.
Alx24
21.184 Vistas
Limit values are given in the documentation for 24bpp that define traffic - 8 bit per color.
That is tab "Color" in Intel Graphics Command Center
or "Settings > Display, Advanced Display Settings"
with "Bit depth 8-bit"
There are very complex dependencies:
https://www.intel.com/content/www/us/en/products/sku/134589/intel-core-i512600k-processor-20m-cache-up-to-4-90-ghz/specifications.html
Intel® Iris® Xe Graphics only: to use the Intel® Iris® Xe brand, the system must be populated with 128-bit (dual channel) memory. Otherwise, use the Intel® UHD brand.
Alx24.
dapxe
Principiante
21.168 Vistas
Hello Andrew G
  I have read the content of your reply. I am not satisfied because the issues I have raised are still not answered clearly and convincingly by you. You are deliberately avoiding answering the problems I have raised in the previous post.Do not redo your posted 2560x1440-75hz video (Because I suspect that you didn't use HDMI 1.4 connection in this video which is the result when you use a different connection other than HDMI 1.4 ).At the same time, you and Alx24 posted many articles with inappropriate content to direct my problem to other unrelated issues. So to get to the final conclusion I suggest you:
  Please answer "yes" or "no" to the question: Does the UHD-750 integrated in the i5-11500 connect to the monitor 2560x1440@75hz via HDMI 1.4 work at 2560x1440@75hz? (In reality, not in theory)
  In case you answered "yes", please make a video with complete, clear and convincing content to illustrate your answer.
  In case you answered "no", you don't have to do anything.
  In case you answer is not clear again, I suggest you stop supporting me in this matter and replace with another customer support technician.
Best regards.
Alx24
21.143 Vistas
Thank you very much dapxe. You are also incredibly pleasant and interesting to deal with.
On your monitor page
https://www.viewsonic.com/ap/products/lcd/VX2780-2K-SHDJ
like nowhere else talks about the advantages of 75Hz over 60Hz
"Smooth Refresh Rate
The VX2780-2K-SHDJ features a 75Hz refresh rate for fluid visuals from web browsing to gaming. Experience the benefits of faster frame loading across your entire PC experience.
75Hz"
when showing dynamic scenes, the corresponding image is shown and it is quite understandable
your deep experiences.
On page
"Technical Resources: Intel® Core™ Processors"
"11th Generation Intel® Core™ Processor Family"
Supporting 11th Generation Intel® Core™ processor families for desktop platform, formerly known as Rocket Lake
Volume 1
https://cdrdv2.intel.com/v1/dl/getContent/634648
Table 2.14 Display Resolutions and Link Bandwidth for Multi-Stream Transport Calculations
Refresh Rate[Hz]
Pixel Clock[MHz]
Link Bandwidth[Gbs]
and consider in it the 3 most important lines
2560 1440 60 241.5 7.25
3840 2160 30 262.75 7.88
2560 1600 60 268.5 8.06
Intel processor graphics from 6th Generation correspond to HDMI 1.4 and support 4K resolution at 24Hz at first,
and now at 30 Hz. Resolution 2560x1440 is supported at 60 Hz, but 2560x1600 only at 30 Hz and in the table
it corresponds to 8.06 Gbs - it is worth remembering.
When connecting 4K display to Intel Graphics HDMI 1.4, it is known for sure that:
2560 1440 60 Hz - HDMI 1.4 60 Hz o.k.
2560 1600 60 Hz - not HDMI 1.4 60 Hz but only 30 Hz.
In this way, this table reflects the principles of Intel Corp. in Graphics.
If you count the number of transmitted color bits by subdiving Link Bandwidth on pixel Clock then in these three cases
you get the number 30 bit.
7.25 Gbs / 241.5 MHz = 30 bit
7.88 Gbs / 262.75 MHz = 30 bit
8.06 Gbs / 268.5 MHz = 30 bit
In this mode, it is impossible to go from enabled 2560x1440 60 Hz to 2560x1440 75 Hz,
but it is possible if the pixel will account for 24 bits or less.
How to achieve this, or it is impossible can tell Intel Corp.
By the way, in the EDID of your display from Report.txt 75 Hz are very detailed:
Vendor Specific Data Block HDMI 1.4
IEEE OUI: 000C03
Source Physical Address: 1000
Supports ACP, ISRC1, ISRC2
Supports 48 bits/pixel (16 bits/color)
Supports 36 bits/pixel (12 bits/color)
Supports 30 bits/pixel (10 bits/color)
Supports YCbCr 4:4:4 Deep Color
Supports Dual DVI
Max TMDS Clock Rate: 310 MHz
Video/Audio Latency Fields Present
75 Hz
Detailed Timing Descriptor
Pixel Clock: 301.85MHz / 75 Hz
Horizontal Active: 2560
Horizontal Blanking: 160
Vertical Active: 1440
Vertical Blanking: 41
Horizontal Sync Offset: 48
Horizontal Sync Pulse: 32
Vertical Sync Offset: 3
Vertical Sync Pulse: 5
Horizontal Display Size: 608
Vertical Display Size: 355
Horizontal Border: 0
Vertical Border: 0
Interlaced: false
Stereo Mode: 0
Sync Type: 3
2-Way Line-Interleaved Stereo: false
(Pixel Clock / (Horizontal Active + Horizontal Blanking)) / (Vertical Active + Vertical Blanking)
(301850000 / (2560.0 + 160)) / (1440.0 + 41) - 74.931981570481
which are feasible at 24bpp if at all.
https://www.philips.co.uk/c-p/275E1S_01/lcd-monitor
After many words here about how good the HDMI interface is:
"HDMI ensures universal digital connectivity
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras)."
for 2560x1440 75hz display recommended to use DisplayPort and specified the required speed of 10.8 Gbps/sec:
"DisplayPort connection for maximum visuals
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters."
From what I said earlier about the lack of HDMI in Microsoft Surface products, you can't make a definitive
conclusion about the attitude of Microsoft Corp. to it because it is quite logically accessible through other high-performance interfaces.
https://www.microsoft.com/en-us/store/collections/cablesconnectorsadapters
"Cables, connectors and adapters"
For your system and your monitor, one of the many USB-DisplayPort adapters would be fine:
https://www.amazon.com/usb-displayport/s?k=usb+to+displayport
The history of your question has been going on for 10 years and you can find including your question when searching
"2560x1440 75 Hz via HDMI"
Alx24.
Alx24
21.078 Vistas
Of course, there is also the option to select the display resolution to use "Custom Resolution" in "Intel Graphics Command Center" which
is called when you click "+" in "Display" in the "Resolution" line next to the combobox with resolution value.
https://www.intel.com/content/www/us/en/support/articles/000056144/graphics/legacy-graphics.html
"How to Set Custom Resolutions and Modes in Intel® Graphics Command Center"
One of the "Basic Custom Resolution" options is similar to using a simple Windows API function "ChangeDisplaySettings"
https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-changedisplaysettingsa
with a small set of parameters, the other uses numerical detailed data from the EDID, which has already been met and discussed here.
It should be noted that displays from different manufacturers have different frequency, line end and frame times and no
correspond exact to the data used by Intel Corp. for data in tables.
Previously, it was proposed to use the USB-DisplayPort connector, as it is more versatile and practical compared to
with a discrete video card with DisplayPort, but you can also use a discrete video card.
First 2560x1440 75Hz display:
https://www.asus.com/us/Commercial-Monitors/PB278Q/
Alx24.
vijay666
Principiante
20.472 Vistas
I am also facing same issue with
Viewsonic VX2480-2K-SHD model which supports the resolution  2560x1440@75HZ
DELL 5410 laptop
Processer - Intel i3 -1125G4
OS - windows 11
Intel UHD graphics version - 30.0.101.1191
If I connect the monitor Via HDMI 1.4 to HDMI I get - 2560x1440@60Hz
Connection HDMI to USB C converter I get - 2560x1440@75HZ
Connection Display port to USB C I get - 2560x1440@75HZ
HDMI to HDMI it is restricted to only 60HZ
I also did same test on Linux OS
Same Dell 5410 laptop
OS - fedora 35
I got the surprising result
HDMI to HDMI -   2560x1440@75HZ
I have not installed any special package here on Linux to get 75hz .It worked natively .
But in Linux I am getting 75Hz and no limitation on HDMI .
I do not understand why we have the limitation on windows 11 HDMI to HDMI only at 60Hz ?
phr
Novato
19.568 Vistas
Probably the difference is in pixel clock - there are two possible modes for 2560x1440@75 Hz:
CVT-RB with pixel clock 304.25 MHz
CVT-RBv2 with pixel clock 295.416 MHz
Since Intel limits pixel clock to 297 MHz for HDMI 1.4, only CVT-RBv2 mode can be used. But e.g. Dell monitors only announce CVT-RB mode in EDID.
See https://tomverbeure.github.io/video_timings_calculator for more details.
gilmarlp
Principiante
19.420 Vistas
Thank you very much!
I was having this problem with my Iris Xe Graphics powered laptop, and with your response I could solve my issue.
Here's what I did, if it helps anyone:
- I was trying to run my 1440p monitor at the maximum supported refresh rate of 75Hz via HDMI;
- The resolution and refresh rate was listed, but I couldn't select it;
- Your reply helped me a lot because I used CRU (custom resolution utility) to set a custom resolution of 1440p @75Hz but with the CVT-RB2 mode, resulting in the 295.416MHz supported by Intel with HDMI 1.4;
- Now my monitor is running at 1440p 75Hz 😁
Responder
