Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel X4500, G41 screen is squeezed in 1920x1080
I just bought ASRock G41M-VS3 R2.0 mainboard with G41 chipset and Intel X4500 on board.
My monitor is samsung P2270, it is connected through D-SUB -> DVI cable.
Now, optimal resolution for this monitor is 1920x1080, but when i select it my screen is not enough wide, on the left and right i have about 2-3 cm black space, the screen is squeezed, fonts are not clear.
I tried to install various drivers, from some old one to the newest but the problem still exists.
Did anyone has the same problem?
Highlighted
Hi marcin,
Can you post a copy of both of the following:
1. Intel* Graphics and Media Control Panel report (CTRL + ALT + F12 -> Options and Support - Information Center - > 'Save')
2. dxdiag: (Start -> Run -> dxdiag -> Save All Information).
Just copy and paste both walls of text here and we'll take a look.
-Nic
Highlighted
Community Manager
Sure, here are the files:
Intel® Sterownik akceleratora grafiki - raport
Report Date: 1/5/2013
Report Time[hr:mm:ss]: 9:11:36
Driver Version: 6.14.10.5160
Operating System: Windows XP Home Edition Dodatek Service Pack 3(5.1.2600)
Default Language: Polish (Poland)
DirectX* Version: 9.0
Physical Memory: 2047 MB
Minimum Graphics Memory: 128 MB
Maximum Graphics Memory: 1024 MB
Graphics Memory in Use: 34 MB
Processor: x86 Family 6 Model 15 Stepping 13
Processor Speed: 1994 MHz
Vendor ID: 8086
Device ID: 2E32
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Intel(R) G41 Express Chipset
Video BIOS: 1676.0
Current Graphics Mode: 1600 by 900
* Other names and brands are the property of their respective owners. *
------------------------------------------------ DX DIAG BELOW ----------------------------------------------------
System Information
Time of this report: 1/5/2013, 09:11:49
Machine name: DOMOWY
Operating System: Windows XP Home Edition (5.1, Build 2600) Dodatek Service Pack 3 (2600.xpsp_sp3_gdr.120821-1629)
Language: Polish (Regional Setting: Polish)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz (2 CPUs)
Memory: 3326MB RAM
Page File: 2145MB used, 3068MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) G41 Express Chipset
Manufacturer: Intel Corporation
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E32&SUBSYS_2E321849&REV_03
Display Memory: 1024.0 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor: Monitor domy Monitor Max Res:
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5160 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/19/2009 12:49:28, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/d
Mini VDD: igxpmp32.sys
Mini VDD Date: 10/19/2009 12:49:30, 6458016 bytes
Device Identifier: {D7B78E66-6D72-11CF-D16F-380EA2C2CB35}
Vendor ID: 0x8086
Device ID: 0x2E32
SubSys ID: 0x2E321849
Revision ID: 0x0003
Revision ID: 0x0003
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Creative Sound Blaster PCI
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1274&DEV_1371&SUBSYS_13711274&REV_06
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: es1371mp.sys
Driver Version: 5.01.3612.0000 (English)
WHQL Logo'd: Yes
Date and Size: 6/3/2002 10:18:32, 40832 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal
Mapowanie MIDI [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
Syntezator SW Microsoft GS Wave [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative Sound Blaster MPU-401 [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, External
Creative Sound Blaster MPU-401 [Emulowany], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mysz
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Klawiatura
Attached: 1
Controller ID: n/a
Highlighted
Thanks for providing that info Marcin. Two things real quick; the first report you saved from the Intel® Graphics and Media Control Panel, does not list the EDID or supported resolutions. This may mean that your machine is not recognizing your monitor or it's included features. Can you verify for me that when you look at the report before doing the 'Save' command, that it lists the supported resolutions and EDID # ?
Also, the dxdiag unfortunately does not include some of the info I was looking for. Can you tell me your system manufacturer and model is? If it's a built-system, can you tell me what make/model the motherboard is?
-Nic
