21220 Discussions
Intel Xe turns to 40Hz randomly (Lenovo Thinkbook)
costas
I have a Lenovo Thinkbook laptop with a 2560x1600 screen. No external screen.
After a period of time it is quite noticeable in Windows that the monitor runs at lower Hz than the typical 60Hz. If I reset the graphics driver (Ctrl + Shift + Windows Key + B) the monitor runs normal again and you can see it, motion is much smoother when moving windows around.
I suspect it has something to do with Adaptive Sync (I think my monitor advertises to the OS it can do 40-60Hz). I have Adaptive Sync disabled in every place I could possibly find but no, monitor randomly turns to lower Hz setting after a period of time.
Any ideas?
Thank you
costas
Maybe by Adaptive Sync I mean Variable Refresh Rate (VRR)
Jose_Intel
Hello @costas
Thank you for posting on the Intel️® communities.
We understand you are experiencing issues with the refresh rate.
Please answer the following:
·      Was it working before?
·      Does it happen when the power source is plugged or only using the internal battery?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Intel Graphics Command Center
Jose B.
costas
Hello @Jose_Intel
1) No, I don't remember it working correctly
2) 90% of the time I have it plugged in but I think the issue is present also on battery
Right now it's running again on low Hz. I've attached the SSU report you've asked but about the second one I have Intel Arc Control installed, not Intel Graphics Command Center.
Jose_Intel
Hello costas
Thank you for the information.
According to the report, you are using our latest generic driver. We highly recommend using the OEM drivers which are handpicked and include customized features and solutions to platform-specific needs. Please download the latest from here: Intel VGA Driver for Windows 11 (64-bit) - ThinkBook 13x G2 IAP
Then, download and run the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics, and install the driver you just downloaded.
Jose B.
costas
Before installing the latest generic I have already done just that. Uninstalled everything with DDU from safe mode and installed the latest from the manufacturer. No luck.
Jose_Intel
Hello costas
Thank you for letting me know.
We will check the issue internally, as soon as we have any update we will let you know.
Jose B.
Jose_Intel
Hello costas
Thank you for patiently waiting.
·      What tool are you using to monitor the refresh rate?
·      Have you checked if Dynamic Refresh Rate Switching is enabled?
·      Does the computer have any control panel that has an option to change refresh rate when not in use?
·      Have you checked the Power Plans?
Jose B.
costas
1) None. Are there any?
3) No, it's a clean Windows installation, no manufacturer or other 3rd party utilities
2, 4) My settings are shown below:
Screenshot 2023-10-16 221601.pngScreenshot 2023-10-16 221546.pngScreenshot 2023-10-16 221524.pngScreenshot 2023-10-16 221248.pngScreenshot 2023-10-16 221224.pngScreenshot 2023-10-16 221201.pngScreenshot 2023-10-16 221136.pngScreenshot 2023-10-16 221123.pngScreenshot 2023-10-16 221102.pngScreenshot 2023-10-16 221051.pngScreenshot 2023-10-16 221026.pngScreenshot 2023-10-16 221000.png
costas
In Global Gettings of Intel Arc control panel it says VRR - Not supported. Why is that? Maybe it has some connection with the following open issue?
https://www.intel.com/content/www/us/en/support/articles/000095363/graphics.html
Jose_Intel
Hello costas
Thank you for sharing that information and the screenshots.
We will continue with the issue internally, we will post any update here.
Jose B.
Jose_Intel
Hello costas
After checking the reports, screenshots and troubleshooting performed so far, we highly recommend checking with the system manufacturer since the “issue” could be related to the Variable Refresh Rate (VRR). https://support.lenovo.com/us/en/
Thank you for understanding.
Jose B.
costas
Dear Jose, I have new findings.
When it turns to lower Hz, I toggle Panel Self Refresh On and Off (I have it turned Off all the time) and it goes to normal 60Hz (without the need to reset the driver as I mentioned in my first post). Maybe that's a clue for your team? It seems it behaves like the setting is On.
