22878 Discussions
Intel graphic control panel not showing
vikky1984
my dell laptop fully updated but my intel controll panel not showing wat about solution help me
LeonWaksman
It is hard to help you after your statement: "...i updates all driver " however on the Sys Info image, I can see that the BIOS is not updated. The lates BIOS for you laptop is version 1.18.0 dated 14 Dec 2023 (you have version 1.8.1 dated 13.12.2017).
I suggest that you should update BIOS and then check if you have the latest drivers as shown on DELL Download page.
Leon
LeonWaksman
Download the Intel Graphics Command Center (Beta) from the Microsoft Store.  Yes, my advice is to download the Beta version as it has more futures that the final version.
Leon
vikky1984
thanks for replying
i updates all driver but im not getting visulization my picture quality blour Intel(R) Core(TM) i5-7300U CPU @ 2.60GHz 2.70 this is my system kindly helpScreenshot (2).png
LeonWaksman
Leon
vikky1984
yes i updated bios again freshly install disply driver also but same problems sirold biosold biosafter update biosafter update bios
vikky1984
compare to privious now image quality is  bit better
LeonWaksman
I'm sorry and can't help you more. I suggest that you should ask for help in Dell Support.
Leon
vikky1984
thanks for your suggestion now after upgrade bios image quality is good thanks lot
