22946 Discusiones
Intel® graphics drivers do not support disabling vsync
Empleados
2.680 Vistas
I just want to know why? Is there any chance to change your mind/policy about it? I really like your products, but this petty problem makes me cry, when your competitors have this option on their product. I never thounght if I buy a laptop in 2012 I won't be able to play an oldschool game on it.
So this list is simply lie: http://www.intel.com/support/graphics/intelhdgraphics3000_2000/sb/CS-032052.htm 2nd Generation Intel� Core� Processors with Intel� HD Graphics 3000/2000 — Game playable with built-in Intel� HD Graphics 3000/2000
0 kudos
5 Respuestas
Fred_D_Intel
Empleados
1.733 Vistas
Hi!
I will send this information to the appropriate department so; they can take it in consideration.
Thanks!
ROBERT_U_Intel
Empleados
1.733 Vistas
Hi Lamerick
Vsync is off by default unless the application running requires it. You can also turn it on full time with the following setting in the Intel Graphics and Media Control Panel.
Empleados
1.733 Vistas
There is a need for many users to disable vsync completely, as some programs enable it by default but can run better without it. The example that brought me here is the game FTL:
http://www.ftlgame.com/forum/viewtopic.php?f=9&t=2422 FTLgame.com : View topic - Low FPS with Intel HD
Empleados
1.733 Vistas
I realize this is an indie game developer, but most games have the option to disable VSync in their local interface. Not saying it wouldn't be nice to be able to do so from the Intel GFX Properties, but it makes more sense for the game specifically to host the option than to have one master control for it.
Empleados
1.733 Vistas
You're right, and I'm going to also request it from the game developer if no one has already. It seems that they think vsync should be turned on while those in the community say the opposite...
http://www.ftlgame.com/?page_id=192# cpu FTL: Faster Than Light
Given that several similar products do have the option, if it's technically feasible it would be a really welcome feature at the very least.
Responder
